406 Coupe - won't switch off
Results 1 to 9 of 9
  • 1 Post By Peter C
Thread: 406 Coupe - won't switch off
    Fellow Frogger! aquinian's Avatar
    WA
    604
    Default 406 Coupe - won't switch off
    Hello all,
    Series of events:
    Key stuck in "on" position and would not turn at all. Removed battery cable to kill it. After much effort we managed to remove the barrel and switch. Picked up a replacement today from a wreck (key, barrel, and switch). Fitted them temporarily (plugged the wires in) and started the car. All good, except that turning the key to the "off" position doesn't stop the car, she keeps running (as she did with the broken barrel/key).
    So I'm wondering if this is a coincidence, or if there's a known issue, or what? In any case, we need to fix it!
    Any advice warmly welcome!
    John.
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    1000+ Posts Peter C's Avatar
    SWOTR
    3,791
    Having had the "pleasure" of dismantling and reassembling a 406 ignition lock, are you sure you've reassembled it correctly - ie the switch part?
    WA
    604
    We didn't dismantle the switch, Peter, we just transplanted it.
    SWOTR
    3,791
    Maybe the switch in the replacement is faulty. The switch in mine was faulty (the engine wouldn't switch off) and after disassembling, cleaning and lubricating the actual switch, all was well. Seeing as your original fault sounds like the barrel rather than the switch, why don't you try swapping over the switch to the replacement barrel? It's a bit fiddly though.
    WA
    604
    Got it working, Peter, however now it cranks and won't start, which I think is the laserline alarm/immobilizer...
    SWOTR
    3,791
    It's a voyage of discovery!
    Tom_95 likes this.
    WA
    604
    Aftermarket stuff!
    1000+ Posts Beano's Avatar
    3,180
    Don't 406s have a red coloured reset button in the engine bay, rear passenger side ? When should it be used, and what exactly does it do ?
    Mar 2011
    413
    My 306 has it as well, lots of cars do. Under that soft button are two electrical contacts, a metal ball and a magnet. The magnet holds the ball against the contacts, completing a circuit to the fuel system. The idea is that in the event of an accident, that metal ball will pop out of place and cut the flow of petrol. Basically a mechanical failsafe.
    2000 306 GTi6 'Josie'
