306 A/c fan
Results 1 to 13 of 13
Like Tree3Likes
  • 1 Post By Grey_Lover
  • 1 Post By ianrobbo
  • 1 Post By Matthew
Thread: 306 A/c fan
    Fellow Frogger! dhaw's Avatar
    Feb 2005
    SYDNEY
    529
    Default 306 A/c fan
    After many years of trouble free motoring the GTI6 is starting to show its age in niggles and aches and pains. Problem this time is that the aircon fan in front of condensor has decided it wants to fly off. Seems to be held on my one phillips head screw in the center. Seems to tighten in the opposite direction to what you would normally expect. Can anyone tell me if it threads into a metal boss or straight into a plastic hub. Before I take the grill out and araldite the bugger.
    Fellow Frogger! Grey_Lover's Avatar
    Sep 2015
    Mornington Peninsula
    144
    Ive replaced my fans before . Just cant remember .. would you believe that there is fans and motors in my kitchen .. just stripped them from my old 306 .
    Im at work .. so cant answer til later .. sry
    206 gti 180
    306 gti 6
    fx holden historic race car
    Don't remind me!
    16,609
    Left handed countersunk head machine screw (Pozidriv) there, possibly missing the crucial countersunk star washer behind it.
    Oct 2003
    623
    The plastic fan can shear off neatly around the screw.
    Feb 2005
    SYDNEY
    529
    Thanks for the replies... definitely no washer on the a/c fan. being countersunk I'm not going to get one. Ideas.....? Its fracking hot out west!
    Feb 2005
    SYDNEY
    529
    Quote Originally Posted by Bluey View Post
    EEEK! Why can't they use a BOLT and a big washer.... arrggh.. French cars. Love to hate them.
    Don't remind me!
    16,609
    The fans are two makes. ECIA fans have a left hand threaded hex bolt and flat star washer plus the drive shaft has a cross pin engaging with the back of the plastic moulding. The other brand have the countersunk screws and washers and are driven by a double flatted shaft.
    Sep 2015
    144
    If you need bits .. let me know . Might be able to help ..
    dhaw likes this.
    206 gti 180
    306 gti 6
    Feb 2005
    SYDNEY
    529
    Whats on the other side of the screw... is it tapping into metal? Argue against this idea.... in place of the washer which I haven't got , as a stop gap measure, I get a piece of rubber inner tube to use as a washer. It would conform to the hole and be resistant to turning due to the grippy rubber. For a while.
    Feb 2005
    SYDNEY
    529
    Hi Addo... I pulled the cowling off and while the screw is located tightly the fan is flopping around on the shaft suggesting the inside of the fan has worn badly. Sound about right? Replacement fan seems to be the only way forward. Any way to pull a fuse and cut the passenger side fan out as I can't easily get to the wiring....? Otherwise no a/c around this country town and only use it on trips.
    Avisford NSW
    550
    I can supply several sets of either type blades but the scres are a problem.
    dhaw likes this.
    1,731
    I have a spare motor around complete with screw if interested.
    dhaw likes this.
    307 HDi wagon
    407 HDi wagon
    Feb 2005
    SYDNEY
    529
    For completeness for people searching threads I found it necessary to unbolt the passenger side of the front bumper to allow space to remove the faulty fan.As you can see from the attached photos the plastic hub around the screw mount had disintegrated. Second hand fan sourced from a Aussiefrogs member will have the car back to AOK.
    306 A/c fan-20160125_091355.jpg306 A/c fan-_r1a4851_ijfr.jpg
