205 GTI - BE1 Gearbox - driveshaft spline count?
    Jul 2014
    20
    Default 205 GTI - BE1 Gearbox - driveshaft spline count?
    My 205 GTI needs both driveshafts replaced. It's an early car with a BE1 gearbox. Does anyone know the inner and outer spline count for the driveshafts? Is it the same as a 205si?
    It's getting harder to find these items but if I can find out that information (without pulling the shafts from the car) I should be able to order some new ones from the UK.
    Sent from my Nexus 4 using Tapatalk
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,444
    Look up and check on the SKF catalogue.
    I think they are all the same spline count and will all fit each other.
    You may probably only need new outer CV joints though. You would need to replace both boots though on each drive shaft.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Jul 2014
    20
    I thought the outer hubs were different at least on the early 205s? I'll have a look on the SKF site though.
    Feb 2006
    North Rocks, Sydney
    2,444
    The hubs have different offsets length/axis wise.
    There are lots of posts here about people fitting bigger brakes that may explain this.
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,609
    Mine is 1987 Gti 1.9 with Be1 - 21/24 for the spline count
    Every day is a good day
    Jul 2014
    20
    Thanks!
