Can of worms?
Results 1 to 16 of 16
Like Tree4Likes
  • 1 Post By robmac
  • 1 Post By DoubleChevron
  • 1 Post By Mike Tippett
  • 1 Post By Bruce Llewellyn
Thread: Can of worms?
    1000+ Posts Dano's Avatar
    Apr 2012
    1,260
    Default Can of worms?
    Just thinking out aloud.
    What oil should I use in a 404 engine rebuild?
    Bearing in mind, that it possibly won't be fired up for another 6-7 months. However during that time, it will be wound over by hand regularly.
    Dano
    19,211
    I've always used a Semi Syth. And run in on a straight mineral oil. Penrite et al have a good range.
    Dano likes this.
    8,426
    Don't use regular oil after a rebuild unless the rings and bore are not touched.
    Use running oil after a rebuild.
    It has less friction modifiers and allows the rings to bed in to the bores during the running in period.
    The engine should run it for a certain time, can't remember but might be 100km or something low, then change to a regular oil full of friction modifyers.
    Jo
    16,494
    I always found this really interesting:
    Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
    cjl likes this.
    Apr 2012
    1,260
    Thanks Shane,
    Yep it's interesting. I'll have to re-read it to absorb and convince myself.
    Dano
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,751
    I would tend to follow Peugeot's own recommendations from the period regarding running in procedure. As for oil, I will face the same question in a couple of years when my Coupé Injection engine is installed in the soon-to-be restored shell.
    robmac likes this.
    1966 Peugeot 404 Coupé Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,553
    That is what I have been doing since my first new car (ended with very strong engine compared to others of the same make) and all my race go kart engines way back when.
    Every day is a good day
    19,211
    I'm 100% with you on this. Use a standard , mineral, non friction modified oil to run in.
    Otherwise you stand to have ring bedding issues.
    As to many and varied theories as to "running in". I follow Mr Peugeot recommendations and drive gently with occasional sessions of higher speeds. Don't let the engine labor.
    Soon enough you you will "feel" when the engine wants to rev harder - just go with it.
    I've found mahl pistons and liner can take a while to bed and can blow smoke for quite a while - eventually they seem to bed in.
    I pull the head down again after the engine has run a 100 ks or so. Usually the next day when stone cold. If you have lubed the head bolts well you don't need to loosen off.
    Pull the head down again at 1000KM, set the tappets, change the oil and filter and if the engine has freed up and not burning any oil / blowing smoke you can change to a semi syth.
    If the engine is still tight or puffing smoke use another sump of non friction modified mineral oil. This time for 2000-3000 km.
    I've done several XN engines this way, and with the exception of one dick owner running the oil too low, have never had any issues.
    Did I remind you check the oil level regularly and often for first 1000 km ?
    Jun 2011
    Brisbane Qld
    20,553
    Spot on and applies to even run in engines. I have seen two engines ruined prematurely by labouring, pinging noise from bottom end at low revs can be the tell tale result.
    Vary the rev range and load the engine, but dont labour it is how I was taught
    Apr 2012
    1,260
    All good advice gentlemen,
    Since I'm using a genuine Peugeot set of NOS piston and sleeves, I'll stick with the tried and tested methods suggested and ones I've used previously. '
    Shane that doesn't mean your advice was incorrect, its just the set (pistons) are old school and I'll stick with what I know.
    Dano
    8,426
    In regards to the original question of which oil...
    Penrite Oil - A Better Class Of Oil
    Jo
    Banned
    sydney, australia
    11,301
    how could you trust someone who formats a website like that??
    16,494
    Because everything he says makes sense. Have you ever noticed hire car and demonstrators always seem to go a LOT better than all the other cars. It will be because they were driven HARD when they were brand new. My CX turbo was a demonstrator when new... CNAN numberplates. It would have been flogged to death my everyone that stepped into the drivers seat. Fast forward 31 years and she still doesn't burn a drip of oil, still has never had the head off .... and still goes quite well.
    Being gentle on a freshly build motor makes no sense to me
    seeya
    8,426
    Being gentle on any motor makes no sense to me
    seeya
    There, fixed for you.
    Jo
    Oct 2011
    Toowoomba
    650
    Hi, Have some more worms. The materials in the Pug are steel liners with chrome faced rings. The perfect circle installation instructions include running the engine up to full speed at full throttle several times - There is a balancing act - the rings need full load to bed in with a running in oil, but the bearings need the opposite. The Pug handbook instructions produce good results and we've run several motors to the next overhaul with 180,000 - 250,000 miles following it.
    www.avweb.com/news/maint/184932-1.html
    Dano likes this.
    Jan 2002
    1,751
    That reminds me: in the KF engines, there is a washer of about 1 mm thickness that goes under the richness lever during break-in. It's left there for 1000 km, at which point it is supposed to be removed at the first service. Many 404 KF cars never had this removed! Mine all have (one was done by me, when the car was 13 years old!), but more importantly, when my KF2 engine is rebuilt I must remember to put this washer in temporarily.
