drive line swap 505 into 504
Results 1 to 17 of 17
    Mar 2005
    launceston, australia
    34
    Default drive line swap 505 into 504
    I have a 505 with all the mechanicals and a 504 that needs an engine and had brake repairs.[ both manual ] How hard would it be to swap the entire drive line from the 505 into the 504
    Cheers...............Wayne
    Dec 2005
    HOBART
    1,265
    Depends what you call easy. I assume you're talking XN1 engine and not DZJ or. ZEJ motors?
    You don't say whether it's an early, middle or late model 504. It's easy with XN1 and either BA10/5 or BA7/5 gearboxes
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    1000+ Posts Beano's Avatar
    3,149
    ^ Wot he said.
    The 505 gearbox is 5 speed and you will need to hit the transmission tunnel with a large hammer to create a little more room. Nothing too dramatic tho.
    Dec 2011
    Athens, Greece
    299
    What model are the cars? The easiest would be to swap everything (including complete front and rear ends). If the 505 is an injection model (ZDJ variant) you will also need to swap fuel tanks and lines.
    Mar 2005
    34
    10/74 for the 504 and overhead cam efi [ douvrin ?] for the 505 . What years constitute early or late for 504? Where and by how mutch do you massage the transmission tunnel? This and changing fuel etc I would consider doable but I would get someone else to do the wiring. Thanks for the replies folks, and Thanos, I am impressed with your marathon car.
    3,149
    I haven't done it, but a Pug mechanic friend told me to just keep a sledge hammer handy for the gearbox fitting. I know it sounds extreme, but basically a heavy one has a lot of momentum. No huge swinging involved.
    Someone else here will be able to tell you specifics.
    Thanos is correct in that the 505 rear end is slightly wider. The rear hubs are a little wider and the drive shafts are a little bit longer. This gives you a wider track and more stable rear end (also looks better). Peujohn did this to his 504.
    Also, 505 drive shafts are more readily available secondhand if another one is ever needed.
    Dec 2002
    Menzies Creek
    2,541
    How handy are you with electrics? Most of the conversion is pretty much bolt-in, but you will have to do some fancy wiring if you want to retain the fuel injection. Option B would be to make an adapter plate to fit a Fuego intake manifold and carby to the OHC motor.
    '74 504 should have the right crossmember to bolt the 505 style engine mounts to. If not, use the 505 crossmember. If you want to use the 505 power steering system, you will also need to use the 504 tie rods on the 504 rack.
    Early 504 (which yours is) would also need a fuel return line fitted to the fuel tank and high-pressure pump fitted for the injection system.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    350
    Have a look in the for sale. There appears to be a great 505 for sale in Tassie. A lot less work?"
    Dec 2011
    Athens, Greece
    299
    I would swap EVERYTHING! Complete front and rear ends with cross members and mounts, radiator mount, fuel tank and fuel lines, gearbox with shifter, drive shaft, steering column including stalks... you get it. You get all the 505 benefits, but in a far better looking and handling car. Transmission tunnel interference is not a problem, I have fitted a BA10/5 in an early 504 coupe without a problem (I used the jack to widen the tunnel around 10 mm in two spots. You will have to roll the lips of the rear guards (easy) and you will end up with 3 degrees negative camber in the front (try it, you will like it).
    Don't remind me!
    16,609
    Surely the wiring is not that hard?
    Blue Mountains, NSW
    433
    Quote Originally Posted by ThanosK View Post
    ... You get all the 505 benefits, but in a far better looking and handling car.
    Far better looking is subjective -- I think both look pretty good in different ways -- but I'd like to know why a 504 body with 505 driveline would handle far better than the 100% 505. It can hardly be aerodynamics. Is the 504's body much more rigid? Much lighter?
    Have fun,
    Rob.
    19,211
    Any wiring that old is hard: both in insulation and to resurrect.
    Dec 2005
    HOBART
    1,265
    Fitting a Douvrin engine into a 504 is a job for someone with a reasonable amount of skill. Well, it's more the work that needs to be done to finish off the job and get the car mobile which will take the skill.
    Unless you've had a good amount of electrical and mechanical experience, I wouldn't recommend it.
    Gerry Mullock
    Dec 2011
    Athens, Greece
    299
    Quote Originally Posted by robs View Post
    ... I'd like to know why a 504 body with 505 driveline would handle far better than the 100% 505.
    I don't know, Rob. But I had two 505's (an STI and a V6) and they did not handle as well as the 504's.And the numbers don't lie: compare the number of 504 rally cars to that of the 505's (it's almost 8 to 1), I am sure there is a reason for that. They both qualify for historic status, so it can't be age related.
    Dec 2002
    Menzies Creek
    2,541
    I agree, but also can't give a definitive reason for it. I suspect it is probably something to do with the weight of a 504 body being concentrated more centrally over a 505 wheel track, or the additional rollover protection in a 505 making the 505 body ever so slightly more top-heavy.
    That said, a completely stripped-out 504 body is about 20kgs heavier than a completely stripped-out 505 body. Not sure where the extra weight comes from (could be the weighbridge at the scrap metal merchants I use, I guess).
    Scotty
    Blue Mountains, NSW
    433
    Thanks for the reply Thanos. "It just does" is fine with me.
    It was largely because of the numbers that I asked. I suppose there might be a few other reasons for opting for a 504 body -- iconic shape, parts availability -- but that they handle better too makes the other things icing on the cake.
    Have fun,
    Rob.
    Dec 2004
    Devonport Tas.
    354
    Hi All
    Another interesting and insightful thread, however as far as comparing handling goes, I think theirs several factors involved such as types of roads and which models. having owned a 504 and numerous 505's, my experience has been that the 504 was good on sealed roads and excellent on gravel ones, 505 GR's and SR's are very similar to the 504, however 505 STi's are better on sealed roads than gravel, my 505 STi executive is brilliant on sealed roads and while good on gravel, not as good as the 504's and 505's first mentioned.
    Regards
    Neil
