Miss Fire just won't go away - GTi 180
Results 1 to 25 of 43
Like Tree9Likes
Thread: Miss Fire just won't go away - GTi 180
    Member flurry's Avatar
    Nov 2012
    37
    Default Miss Fire just won't go away - GTi 180
    Hi Guys
    I've got a really intermittent missfire with my 180. Sometimes your start her up (following procedure) and she runs like a dream, other times idling is awful and feels like only three cylinders are firing.
    So far I have tried:-
    New Coil Pack
    New Plugs
    Cleaning Cam Sensor
    Cleaning Coil Pack Connector
    Cleaning Connector to a strange round metal device which bolts in next to cylinder 1 (looking front on at the vehicle)
    The fault codes I'm getting are:-
    Current Fault Log
    P1336: [Chrysler] Crankshaft Position (CKP) System Variation Not Learned
    [Honda] CSF Sensor Intermittent Interruption
    [Nissan] Crankshaft Position Sensor (CKPS)
    [Mitsubishi] Piston position sensor 2
    [Dodge] Crankshaft Position (CKP) System Variation Not Learned
    [Jeep] Crankshaft Position (CKP) System Variation Not Learned
    [Seat/Audi/Volkswagen] Engine Torque Monitoring Adaptation at limit
    P0354: Ignition Coil "D" Primary/Secondary Circuit
    Pending Fault Log
    P0341: Camshaft Position Sensor "A" Circuit Range/Performance (Bank 1 or Single Sensor)
    Any help from you guys would be very much appreciated, I've had this issue on and off for ages and it's driving me nuts.
    19,211
    When I saw the thread title I thought it was about a female Fuego...
    Sorry, no help at all...
    Fellow Frogger! Grey_Lover's Avatar
    Sep 2015
    Mornington Peninsula
    144
    Have you tried cleaning all sensors ? Maybe cleaning air pump sensor .. im sure there is one . Is this just on start up ?
    206 gti 180
    306 gti 6
    fx holden historic race car
    Fellow Frogger! Pug4eva's Avatar
    580
    Might be worth a shot, have you changed the fuel filter or pump at all? I know the error codes indicate otherwise. Also what petrol stations and what RON do you fill up? I recommend BP 98.
    Grey_Lover and pug206gti like this.
    In Australia: 05 206 GTi 180 and '97 406 v6
    In Lebanon: 09 C3 Exclusive
    All in Silver
    Previously '01 206 GTi
    Nov 2012
    37
    Quote Originally Posted by Pug4eva View Post
    Yep new fuel filter a few weeks ago and a whole new fuel tank and pump last year :-(
    So now I've lost the Camshaft Position Sensor error and am back to good old P0354: Ignition Coil "D" Primary/Secondary Circuit
    Mostly use Caltex Vortex but occasionally V-Power. Is there a fuel I shouldnt be using?
    Thanks guys
    Nov 2012
    37
    Quote Originally Posted by Grey_Lover View Post
    I've tried cleaning all the ones I could get access to.
    It can happen at any time, earlier on on startup she ran fine almost all the way home and then randomly went back to three cylinders and limped home.
    Sep 2015
    144
    Wot brand coil pack ?
    206 gti 180
    306 gti 6
    Nov 2012
    37
    I think its a Sagem one, its for the RFK VIN.
    Sep 2015
    144
    Tricky problem .. are your rocker cover seals leaking badly ? Like making a spark plug swim in oil ?
    206 gti 180
    306 gti 6
    Nov 2012
    37
    Everything looks pretty nice and dry, can't find any leaks. I took it to a garage and they more or less washed their hands with it and wouldn't investigate further other than telling me its an electrical problem.
    Sep 2015
    144
    Unplug clean replug the vvt solenoid ? Ive heard this can fix quirky problems .. The 180s are a strange machine . Sry .. wish i could help more ..
    206 gti 180
    306 gti 6
    Nov 2012
    37
    No worries thanks for the info. Is the VVT solenoid the thing next to spark plug number 1?
    Sep 2015
    144
    Sounds like the one .. battery changed at all ? Wouldnt hurt .
    206 gti 180
    306 gti 6
    Nov 2012
    37
    Yeah I took that out and cleaned it and engine seems to be running ok again but for how long who knows. Yeah battery about 12 months old too.
    Sep 2015
    144
    Btw .. i think the brand name sagem causes misfires .. maybe try ngk or valeo . Is the coil pack new ? I thought peugeot dropped them as a supplier
    206 gti 180
    306 gti 6
    Nov 2012
    37
    Ah yeah you're right it's a valeo one I've got
    Don't remind me!
    16,609
    Does the misfire continue or is it only immediately upon startup?
    Armidale
    2,458
    See Post #6 ...
    Nov 2012
    37
    Just wondering could a malfunctioning plug cause this issue? I recently put some new ones in and set the gap to be 0.9.
    Don't remind me!
    16,609
    A cracked insulator may. Can you get a decent diagnostic rig on, to at least determine the cylinder pair? Then you could transpose plugs to test the idea.
    Nov 2012
    37
    I've only got the odb2 reader so may have to garage it to get a more advanced read out
    Fellow Frogger! ipb205's Avatar
    Wright ACT
    567
    Maybe clean or replace the crank angle sensor if not done already?
    I found this link in the UK on the same issue - The Peugeot 206 Info Exchange ? Forums ? The Car ? 206 Problems ? Another misfiring problem, unsanely difficult to solve!
    They had a gasket breaking down sucking in air at the intake manifold area. Might be worth checking. A chunk of gasket ended up on the injector in this case!
    Nov 2012
    37
    Quote Originally Posted by ipb205 View Post
    I think I've cleaned that one already I'm thinking of taking out the MAP and cleaning that
    Sep 2015
    144
    Acually .. how old are the injectors ? Any idea ?
    206 gti 180
    306 gti 6
    Don't remind me!
    16,609
    You've got to do something pretty dramatic to affect your injectors. If you're worried, inspect a random one.
