407 hDI starting issue
Results 1 to 3 of 3
    Jul 2015
    13
    Default 407 hDI starting issue
    Car fired once and then died - turns over ok just not firing
    It was left outside during heavy rain overnight - thinking water/moisture any ideas what to do ?
    thanks
    Jul 2015
    13
    It seems to be leaking diesel where the diesel filter is. Could be sucking air in .
    Mechanics busy or away this time of year .
    Anyone want a cheap Peugeot?
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    364
    The diesel leak is most likely the cause if you starting problem. Try pumping the hand primer before you start it. you will probably find that it will start.
    Diesel leaks are easy and cheap to fix. Most likely it's an o-ring or a faulty bleed/drain plug.
