Installation - DENSION GWP1PC1 Gateway Pro BT
Results 1 to 3 of 3
    Jun 2011
    Tasmania
    2
    Default Installation - DENSION GWP1PC1 Gateway Pro BT
    Hi,
    has anyone successfully installed a Dension gateway pro into a 2009 407? Not having much luck with the process and the installation manual is minimalist in nature,and you tube fails to be useful!
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,777
    I have one in a Megane. It's pretty good but can sometimes need a software reboot off a usb.
    In the megane it's plugged into the CD stacker port on the HU.
    Dec 2010
    Central Coast NSW
    32
    Did you enable the CD changer port
    "The Gateway Pro emulates a CD changer (in most cases) therefore generally no programming is required or the Pro is capable to do activation during the first Power ON circle (typically on Peugeot). On CAN BAP based systems (like RCD310, 510 or RNS510) the Pro emulates the factory MDI (Multimedia Interface) and Telephone option which needs to be coded since Model Year 2011. If your vehicle has not been programmed before, the Media Player 3(2E) and Telephone (7E) options have to be coded in order for the Pro to work correctly. Please note: Programming is not required if your vehicle had those options enabled before"
