307 EGR valve failure
  • 1 Post By WLB
Thread: 307 EGR valve failure
    Oct 2003
    canberra
    857
    Default 307 EGR valve failure
    EGR valve in 307 hdi 2l 100Kw fails inevitably
    quite difficult to access it at back of the motor
    some suggest blanking plates ,
    others suggest disconnecting the vacumn hose
    has anyone disabled the EGR function in the Ecu here???
    as suggested on a UK forum ?
    8,427
    Quote Originally Posted by alpine View Post
    Ask on the VW forum perhaps.
    jo
    WLB
    WLB is offline
    1000+ Posts WLB's Avatar
    Warragul, Vic.
    1,114
    Can anyone please explain the point of EGR? It seems to me that it is in fact closely related to the VW issue in that it appears to be doing something beneficial, but isn't really.
    You take a tiny amount of the exhaust gas and recirculate it so as to burn off any unburnt fuel etc. and in doing so you slightly bugger up the combustion process. If you recirculated a meaningful amount of exhaust gas so as to really improve the emissions, the engine wouldn't run. What is the actual point?
    Please enlighten me if you know the answer.
    8,965
    Diesels operate with excess air. The idea is to dilute the oxygen in the incoming charge - exhaust is naturally oxygen deficient and carbon dioxide is present. The lowering of combustion temperature kills off much nitrogen oxide formation. It's about pollution, but reduced cylinder/head temperature isn't bad. The power loss is a compromise.
    WLB
    WLB is offline
    Warragul, Vic.
    1,114
    Now it makes sense. Thankyou.
    When I've tried it myself using a paper bag, I've only found that it stops me being agitated; or puts me to sleep.
    Roland likes this.
