BE3 Gearbox Swap Questions
Like Tree4Likes
  • 2 Post By Pug_405_Mi16
  • 1 Post By schlitzaugen
  • 1 Post By Wintermute
Thread: BE3 Gearbox Swap Questions
    Fellow Frogger! FedGrapes's Avatar
    Aug 2011
    Perth, WA
    836
    Default BE3 Gearbox Swap Questions
    Hi everyone!
    I'm in the process of swapping the gearbox in the S16, and I've got a question regarding what needs to come out.
    Do I need to remove the drive shafts as described in the Haynes? Can I just pop them out of the diff, and leave everything else in situ? I don't have the tool they recommend for holding the hub in place while you do the centre. I also am not keen on finding new bolts if I don't have to.
    I have removed the starter, the battery (and accessories), and the air filter (and ducting etc). The intake manifold is off, and I'll redo all the vacuum hoses while stuff is out (half broke, anyway!)
    Cheers!
    Hobart
    1,496
    Hello,
    I haven't done a 306, but have done several 405's and 205's which are essentially the same thing. Shafts have to come all the way out, not sure what bolts you need but you just need to get the hub nuts off (hard) and then undo the hockeystick bolts on the long shaft and then take the hubs off the struts to allow enough movement to get them out. I've changed the box without taking the subframe out but it takes a lot of jiggling.
    Good luck!
    FedGrapes and lion5 like this.
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    9,060
    On a 205 it's a PITA to do it like that.
    By the time you're done jiggling (and knocking) things about, you're better off dropping the engine and g'box on the deck and out by lifting and rolling the shell back. Even easier if you have a garage crawler to drop the whole thing on and slide it out from under the shell - still need to lift the shell a bit.
    You need to disconnect the callipers and hubs off the struts or the strut tops - whichever way you fancy - I just find it easier to leave the struts in the car.
    You have to disconnect the support bearing carrier from the subframe (leave attached to the block - you will have to disconnect it from the block later to take the g'box away, or you're in for some jiggling when lining up the new g'box - again a matter of taste). I don't like taking the subframe out because it messes with your steering alignment.
    You might need to disconnect the sway bar from the drop links and swing it out of the way.
    And of course, the gearshift linkages, tie rods, the lower suspension arms.
    And the g'box needs to be drained before you start anything, of course. But you knew that.
    I like to take everything off the engine before dropping the assembly. Like, really everything. Avoids damage from inevitable unforseen.
    FedGrapes likes this.
    ACHTUNG ALLES LOOKENPEEPERS
    Apr 2005
    866
    Hi Fedgrapes! Having been through it, have a read through my experience!! 306 S16 gearbox removal
    Get the right size socket for the drive-shaft nuts! (I think it is 35mm I got 36mm and somewhat munged the nuts, pretty sure the right size is in the thread)... Anything that looks like you might need to take it off do it!!
    The cable tray that runs over the gearbox is an absolute PITA.
    Take many photos as you go!
    DO drop the rear of the subframe down a few cm when you get to removing the box, it WILL make your life a whole lot easier!! (You only need to undo the bolt on the left from memory and don't take it all the way out, just lower the subframe on that side down a few CM, it makes a big difference! PeterT recommended it to me, and I didn't do it at first as I was worried about alignment, but in the end I did it and wished I'd done it earlier. No issues with misaligning either.
    DO have two people to take it out and put it back in!!
    Anyway hopefully reading through my experience may help you to avoid some of the problems!
    edit: DO take not of cav91's post #6 in my above linked thread about the 11mm nuts!
    from memory I dropped the ball joints from the struts so that I could manouver the drive shaft out, but it may be easier to remove the ball joint from the suspension arm (though that might be what you are talking about with new nuts/bolts.)....
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
