"I just swapped the pedal box complete - there were subtle differences despite the pressed steel assembly notionally being the same." Haakon.
You make it sound easy!
What's involved i getting the pedal box out to change from hydraulic to cable?
Easiest way?
The cable box has a cable mounting guide . Without this tube in place the cable isn't anchored as it works through an angle , rather than at right angles to the firewall.
How long to change and best way.
For a start adult hands are way to big and the relay rod seems to get in the way as it is connected???
