Gti 6 rear fuel leak
Results 1 to 12 of 12
  • 1 Post By PeterT
Thread: Gti 6 rear fuel leak
    Fellow Frogger! Grey_Lover's Avatar
    Sep 2015
    Mornington Peninsula
    144
    Default Gti 6 rear fuel leak
    Hey there .. filled right up 2day and walking back from paying i noticed a fuel leak coming from the rear . Its now stopped . So im thinking its the rubber fuel filler connector or return line if theres one ? Any thoughts please thnx Gti 6 rear fuel leak-uploadfromtaptalk1449029105618.jpgGti 6 rear fuel leak-uploadfromtaptalk1449029121415.jpg
    206 gti 180
    306 gti 6
    fx holden historic race car
    7,487
    Most likely the valve thingy on the side of the tank, just above the filler entry.
    BIGRR likes this.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,444
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Sep 2015
    144
    Hey thnx guys . I still have my n5 97 xsi which ive been stipping . Would the tank fit or steal bits from it to fix this problem ?
    206 gti 180
    306 gti 6
    Sep 2015
    144
    Ok .. replaced the 90 elbow today and yup.. still leaking . The elbow did have a pinch hole through it where the clamp does up so im happy i changed it . Im sure its leaking from this valve thingy pictured .
    I filled up and all was good untill it leaked again . I raced home .. took wheel off and heard a hissing/ pftt type noise think it is the side valve ? It was really wet with fuel . Everything around it look clean
    Gti 6 rear fuel leak-uploadfromtaptalk1449387567807.jpgGti 6 rear fuel leak-uploadfromtaptalk1449387605084.jpg . So if i was to bypass it . How should i do it ?
    Take the insides out ? Or put another fitting piece there ?
    206 gti 180
    306 gti 6
    Feb 2006
    North Rocks, Sydney
    2,444
    does your other 306 have the same fitting?
    From memory the daughter's late Xsi only leaked when 'the tank was full/overfilled, I think I stuck some type of bung in the hole that the fuel was coming out of. It was 2 or 3 years ago and it had no leaks after. (Sorry can't remember which hole I bunged off).
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    Sep 2015
    144
    Hey thnx . Was wondering if i could bung . Im trying to be safe about this .. cause it is fuel . I am planning to check the 97 n5 xsi 2moz for fitting ..
    206 gti 180
    306 gti 6
    7,487
    I'll take a picture of my hack job tomorrow.
    Sep 2015
    144
    Btw .. mine only leaks when full/overfilled too .. but shouldn't
    206 gti 180
    306 gti 6
    Sep 2015
    144
    Fantastic Peter T
    206 gti 180
    306 gti 6
    Sep 2015
    144
    peter .. are these the 2 lines you made into one ? The 2 going to the valve ? So then it would be fully bypassed ?
    206 gti 180
    306 gti 6
    Sep 2015
    144
    Ok .. its stopped leaking after i bypassed the plastic thingy on side . I used 1/4 steel fuel pipe to make a join . Gti 6 rear fuel leak-uploadfromtaptalk1449819037355.jpgGti 6 rear fuel leak-uploadfromtaptalk1449819069148.jpg
    206 gti 180
    306 gti 6
