Hi all
I have a set of pistons from an XN1 engine (the cylinder block is gone already). I wonder if someone can tell me what CR they are.
Their height is between 72 and 73 mm, and the crown is + 2.5 mm.
Couple of pistons catalogues (King pistons and Aprotec pistons) didn't shed a light and just confused me more, they are probably not mistake-less.
I think the engine code was AXV, which should be according to a Peugeot bulletin an export engine with 8:1 CR and a MIMSA carb, but it had a TMIMA.
Thx
