Earthing issue - 505 Diesel
    Hobart
    1,496
    Default Earthing issue - 505 Diesel
    Morning All,
    I've got a strange problem with the electrics on my Diesel 505 which I am assuming is linked to an earthing problem. When you brake, turn the indicators on or use the electric windows the temp gauge and fuel gauge needles fluctuate. I assume it's an earthing issue and have confirmed a good earth from the battery and cleaned up all the earth points I can find.
    It's a weird issue and I am wondering if anyone else has had similar problems?
    Also, I have connected the tacho up via the sensor looking at the flywheel and it still isn't working, am I missing something?
    Anyway, thanks in advance.
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Our most Southern Member (Tas)
    277
    Try the trailer plug at the back for a short.
    Don't remind me!
    16,609
    Good spot! I was thinking tail light clusters, else an alternator issue. This latter possibility could be addressed by temporarily blinding off the alternator terminals and running only on a charged battery.
    Hobart
    1,496
    Thanks Bobby, I'll head in that direction.
    Thanks Adam, onto second alternator with same faults and different engine bay wiring loom so confident all OK there.
    Ben
    1973 Peugeot 504 GL
