504 Minimum head thickness
Results 1 to 8 of 8
  • 1 Post By tonch504
Thread: 504 Minimum head thickness
    Slovenia
    198
    Default 504 Minimum head thickness
    Hi all,
    Can anyone tell me the minimum allowable thickness of a 504 alloy cylinder head. Mine has been machined a few times and I'm not sure I can have it done again. It's a Ti head, so replacement is difficult considering their rarity. Thanks in advance.
    Perth Western Australia
    2,694
    Touch,
    The figure of 91mm is scribbled on my tool board. In my case it would be for carb 504.
    Jul 2005
    328
    Factory Manual indicates 92mm, +/- 0.15
    Stock being 92.5mm, and max. out of true 0.05mm
    Couldn't find anything to indicate a difference between for the injected head.
    Perhaps your figure is less conservative but real-world tested 'Beest?
    '96 Peugeot 405 SRDT Station Wagon
    '71 Peugeot 504 GL - gone
    '91 Peugeot 205si - gone
    1000+ Posts Peter C's Avatar
    SWOTR
    3,649
    Quote Originally Posted by scatterbrain View Post
    I also found those figures in the Factory Manual. I thought I could remember 91mm being quoted in other posts but couldn't find that in the good book.
    Slovenia
    198
    Thanks all, I have 91.7, so should be all good.
    Wildebeest likes this.
    Dec 2011
    Athens, Greece
    300
    Quote Originally Posted by tonch504 View Post
    You can easily skim it down to 90.5 mm. Even if you have to go lower than that (perhaps to re-true after a blown head gasket), you can always compensate by using a 2 mm copper head gasket.
    1000+ Posts Beano's Avatar
    3,149
    And a liberal application of Hylomar to both sides !
    Slovenia
    198
    Yep I use Hylomar. But don't put synthetic/waterless coolant in it. It will get out every time.
