504 window seals
    Dec 2010
    TAREE AUSTRALIA
    44
    Default 504 window seals
    Hi,
    has anyone played with their new window seals yet,and would you like to share the removal and fitting process
    and more importantly the result.
    Fellow Frogger! leftcoast's Avatar
    Feb 2011
    perth
    175
    ive put in a front and back before, used plastic levers and a sharp sharp stanly knife to remove, (watch ya paint),
    for installation clean everything first then use the rope "trick" best goggle it as its hard to explain, use 2 people for it and soapy water in a spray bottle.
    search on youtube and there are a few tutorials, good luck
    Blue Mountains, NSW
    438
    leftcoast: You're talking about windscreen seals, but I'm pretty sure the question was about the recently group-purchased window scraper rubbers. I can't help with justpugs's question, but thought it worth pointing this out in case he starts sharpening his Stanley knife.
    Have fun,
    Rob.
    Fellow Frogger! Pug72's Avatar
    Feb 2013
    319
    Yes I have done it...and posted a thread a few months ago. Even though I have recently purchased the seal as part of the group buy, I sourced a good second hand rubber and put that in.
    Search using my user name might the quickest
    Feb 2011
    perth
    175
    Haha, got ya, thats one way to confuse a poor lad, the seals your talking about are very tricky indeed, sorry I can't help either as have not done them yet - good luck
    Feb 2013
    319
    Ok...what else is there to do on a Friday night......
    One down, 3 to go! The new rubber is fairly easy to install compared with removing the old harden rubber.
    I left a little overhang on the ends to allow for shrinkage, but will see how this goes and may trim back closer to a neat finish
    Attached Thumbnails Attached Thumbnails 504 window seals-img_1344.jpg   504 window seals-img_1345.jpg   504 window seals-img_1340.jpg   504 window seals-img_1341.jpg
