2004 206 GTi 180 - Water Pump / Timing Belt Noise?
Results 1 to 8 of 8
  • 1 Post By pug206gti
Thread: 2004 206 GTi 180 - Water Pump / Timing Belt Noise?
    Tadpole StuartVaughan's Avatar
    Oct 2015
    5
    Default 2004 206 GTi 180 - Water Pump / Timing Belt Noise?
    Hi guys, bought myself a second hand 206 GTi 180 a month ago, with no mechanical issues, or leaks present. Over the past few weeks however I've started to notice this odd sound coming from the timing belt/water pump area. Not having much experience myself, its difficult to determine exactly what it is, hopefully this video provides you with a better insight.
    The temp gauge sits around the 90degrees mark, engine oil was changed by myself approx 500km ago (Penrite 5w-40, Ryco Z543 Oil Filter).
    Info on the car:
    Km's: 115,000
    Prod.: Jan 2004
    Service History:
    2004 206 GTi 180 - Water Pump / Timing Belt Noise?-img_8638.jpg
    Thanks!
    Don't remind me!
    16,609
    Struth. Doesn't sound "normal".
    I'm surmising a gutted cat is part of what the sound may be, the rest - well, maybe a good idea to check it out. Does the noise diminish if you run without the auxiliary belt fitted?
    1000+ Posts Peter C's Avatar
    SWOTR
    3,652
    You sure it's not coming from the alternator?
    Oct 2015
    5
    Cheers for the replies, no I haven't tried taking the belt off because I didn't want to have to if I didn't need to!
    It could be the alternator yeah, but what's the best way to check for that in this particular case?
    Don't remind me!
    16,609
    Take the aux belt off. If the noise stops, it's in the aux belt "circuit" (ie, idler, tensioner, PAS pump, alternator, AC compressor).
    For that matter, see if the noise changes with your AC on or off.
    SWOTR
    3,652
    Unfortunately, there's usually no quick and easy way to diagnose noises such as this one.
    lost
    11,055
    Icon6
    G'day,
    you could try making a stethoscope from a piece of hose and an old screwdriver blade [or similar]. With one end of the hose in your ear, try touching various parts with the metal end. It is surprising what you can hear, and feel, BUT, be very careful of moving parts.
    ps..I had a water pump 'issue', but it sounded like the noise when you drag a stick along the concrete. How does yours sound when you are moving ?
    lion5 likes this.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    though it doesn't sound like a chirping noise (clutch) try see if the noise changes as the clutch is depressed.
    tbh it sounds like an aux belt noise to me, try revving it or as addo mentions turn on AC, it should increase in speed
    though looking at your video, within the first six seconds, from what i can see of the PAS the belt looks like its flashing white at various bits? maybe that's just the video interlacing with the speed of the belt but the belt looks weird from that angle.
    have someone turn the steering wheel while the car is idleing, and keep an eye on the aux belt
