504 no spark
Results 1 to 8 of 8
Thread: 504 no spark
    158
    Default 504 no spark
    Trying to start my 504 since engine has been apart . Have switched +12 volts to +ve of coil with the other terminal connected to points . The system is very basic but I can't see what is wrong . Points are opening and closing as I turn engine over and I presume distributor shaft rotates clockwise . Possibly a coil ? What is best way to test this . Any ideas would be greatly appreciated . It cannot be much . Thanks in advance , Keith
    Don't remind me!
    16,609
    Ignition on, plug a lead into the coil and poke the loose end near the engine block. Open and close the points by pushing with a screwdriver. You should get a spark each time they open.
    158
    I have an in line spark tester that does not pulse but I will try your method tomorrow . Much simpler , Thanks
    Dec 2005
    HOBART
    1,265
    Its just possible that you have the distributor shaft 180 degrees out.
    However the lack of any electrical impulses. Check the connections in the distributor
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    158
    Did a check for spark as Addo suggested . It has spark but doesn't seem very strong but I might be used to modern ignition systems I think . I checked the timing with a test light and the ignition appears to be retarded by a mile (about 100mm on the crankshaft pulley) . This will be my problem I hope but I will change the coil just to see if that makes a difference to the spark quality . I have not had the car running since I got it so the timing is an unknown
    Don't remind me!
    16,609
    Are the plugs out one cylinder on the cap? Is the condenser dying?
    Also set your dwell time, not points gap - it's more accurate.
    158
    The rotor button is pointing roughly at No 1 spark plug lead . I checked this by a test lamp between the coil connection to the points and earth .Light goes out when points open to generate spark . I am not sure about the condenser yet . Once the car starts I can set the dwell . What are the symptoms of a faulty condenser . Can I disconnect it to fault find ? Could the distributor drive gear be one tooth out ?
    Perth Western Australia
    2,694
    Distributor drive shaft could be 180 deg out [half turn].
    Peugeot lesson. No1 cylinder is nearest flywheel.
    True test of No1 cyl on firing stroke is when both valves are closed at TDC.
