Peugeot 308 Locknut replacement.
Like Tree6Likes
  • 3 Post By seasink
  • 3 Post By AusGrenouille
Thread: Peugeot 308 Locknut replacement.
    Sep 2015
    AU
    6
    Default Peugeot 308 Locknut replacement.
    Hey guys,
    i noticed my locknut needs replacing the 4 grooves that are suppose to be there is now only 1, anybody know cheaper alternatives on how to obtain a new one? I spoke to a Peugeot Dealer which quoted me $190 dollars for a new one which I thought was pretty steep! Any help would be appreciated! Thanks in advance
    Sent from my SM-G900I using Tapatalk
    9,050
    Is this about mag wheels? If so, do what Citroen owners do - get rid of them.
    Wildebeest, TrinityJayOne and UFO like this.
    Oct 2015
    Galston
    2
    Default Broken Locknuts
    Quote Originally Posted by engzee View Post
    Hey guys,
    I replaced mine with normal nuts after the last tyre change when the gorilla used an impact gun and destroyed them
    Apr 2011
    Nowra
    112
    Don't wait till the head of the stud is so badly deformed that the security nut just slips, no matter how hard you try to keep it in place. If you have already reached that stage the easiest way to get the damaged studs out is to use a cross brace and a scissor jack. Park the car next to a wall and while holding the cross brace in place the jack against the wall and wind it tight, really tight. Remove all the studs and toss them as far as you can and replace with standard studs from a wrecker.
    pug206gti, TrinityJayOne and UFO like this.
    Member Hugh Venables's Avatar
    Mar 2012
    Ferntree Gully Vic
    102
    It seems that this thread is more about wheel bolts than any sort of locknut. If so there is a similar thread up titled "307 wheel security stud problem" which may be useful if the bolts are the same on a 308 even if if the "stud" reference is incorrect........
    Hugh
