Originally Posted by
mistareno
If its the engine with the air filter mounted on top of the engine, it couldn't hurt.
Most of the temperature would be added post compression, but if you can feed cooler, more dense air into the turbo, the compressor will be more efficient, work less hard and as a result will add less heat. But we are talking small improvements.
It won't compare to adding an intercooler, but with no other mods (boost increase/remap) adding an intercooler would just reduce performance.
