Radio mystery
Thread: Radio mystery
    Member Napoleon's Avatar
    May 2012
    Hobart
    36
    Default Radio mystery
    2003 Peugeot 406 Coupe. Radio works on AM & FM when ignition switched on accessory mode. When ignition is switched on fully (start and run) the car the radio only works on FM mode. In other words if I want to listen to AM, I have to park the car. This appears to me even more of a mystery than the meaning of life. Has anybody experienced this problem and if so what is the fix - please?
    Dec 2005
    HOBART
    1,265
    Peter, my thoughts are along the lines of the ignition switch. Another fault generated by new technology, not found in earlier cars.
    If this is the case, unless the switch can be cleaned, the only solution is to replace it.
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Oct 2012
    Armadale, Melbourne
    255
    Just a thought, does the 406 coupe have a proper aerial or an in glass one? My volvo 850 wagon lost FM but turned out it was a defective signal booster for the aerial conveniently located in the rear side window.
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,445
    Quote Originally Posted by dave_R16TS View Post
    My thoughts also. If it has an aerial booster, it may be getting power feed with Accessories but not when the ignition switch is in Run position. Whereas if the radio is working on FM only, then at least it must be getting power from the ignition switch in Run position.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
