Pug 404 cylinder head identification
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By Dano
  • 1 Post By 2pac
Thread: Pug 404 cylinder head identification
    Feb 2012
    Malaysia
    176
    Default Pug 404 cylinder head identification
    Guys,
    how can you tell what model this cylinder head belong to?
    Pug 404 cylinder head identification-20151017_173529.jpgPug 404 cylinder head identification-20151017_173551.jpgPug 404 cylinder head identification-20151017_173820.jpg
    1000+ Posts Dano's Avatar
    Apr 2012
    1,284
    Peugeotnut,
    Hope this is helpful.
    If you'd like a digital version of the parts manual, send me a PM with your postal details.
    Dano
    Attached Thumbnails Attached Thumbnails Pug 404 cylinder head identification-head-info.jpg
    2pac likes this.
    9,278
    A view of the inlet side would be helpful.
    It is probably for an xc7 1972 model, looking at the date Cast on the head.
    Quote Originally Posted by peugeotnut View Post
    Guys,
ID:	75797Click image for larger version.
ID:	75798Click image for larger version.
    Feb 2012
    Malaysia
    176
    Graham.... sadly I did not snap a picture of the inlet side.
    I'm trying to avoid opening my 404 head just to check compatibility.
    Feb 2013
    israel
    822
    it's stamped XM.
    Wildebeest likes this.
    9,278
    Quote Originally Posted by 2pac View Post
    it's stamped XM.
    Yes, the later 404 heads are stamped XM for some reason, maybe they share the casting withe the 504 1.8 heads.
    Apr 2005
    Gundaroo
    124
    It looks like an 1800 head - the inlet manifold area (what little can be seen) suggests that the inlet manifold has four mounting bolts ( the casting lugs for the two bottom inlet manifold mounting bolts are visible) hence 1796 cc head. A picture of inlet manifold side of head should confirm possibly.
    JohnT
    Member Grenouille's Avatar
    NSW, Aust
    115
    my 2 cents worth..
    3 bolt or 4 bolt inlet as above?
    also 3 or 4 welsh plugs on the inlet side?
    I have a head with XC7 cast in - 4 welsh plugs & I believe that to be from a 71 or later
    also the oil & water journals vary slightly from different years - if you can sit a head gasket on it this will help ID it.
    Feb 2012
    Malaysia
    176
    Guys,
    Thanks for all the inputs.
