306 brake lights
    Mar 2015
    Wollongong
    12
    Default 306 brake lights
    My 306 just failed rego because the brake lights are on all the time. My mechanic has no clue how to fix this and my rego is out today. Any suggestions?
    Don't remind me!
    16,609
    It's probably the brake light switch being stuck "on", this could be replaced with a new or used part. Some wriggling under the dash and a bit of swearing, but nothing major.
    The brake light switch has a whitish or maroon coloured plug on it, and it's tucked up near the top of where your brake pedal mounts.
    Jul 2015
    Brisbane, Northside
    108
    Likely the switch under the pedal. I've done mine the in Coupe, and the genuine part from Peugeot was about $40 (for memory). My neighbour's Accord had this issue and I managed to sort it out for her without sourcing a new part.
    Mar 2015
    Wollongong
    12
    So I had a feel around and took it to a different mechanic today who still can't find the switch. Any other ideas?
    Next step is an electrician and hope that he can find it. I'd rather not spend the money if I can help it.
    1000+ Posts pgti6's Avatar
    May 2001
    1,625
    From memory, it sits in front of the brake pedal pivot-up high. A mirror can be a handy accessory for a mechanic when looking for such things under the dash!
    Attached Thumbnails Attached Thumbnails 306 brake lights-306-brake-switch.jpg
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,447
    You have to pull the bottom steering switch cover off, then undo the 4 nuts that hold the steering column to the box section above and let the steering wheel and its column drop a bit, the switch is in the box section that the steering column drops out of, near the firewall. The switch is a push fit into its position and it must be fiddled with a bit by trial and error to make sure it works. You will need a new switch. Probably 20 minutes work all up.
    If your car is auto the brake light switch is the one closest to the passenger side.
    Good Luck
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
