Peugeot 206 manual conversion?
Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By Ikenna351
Thread: Peugeot 206 manual conversion?
    Jerangle
    784
    Default Peugeot 206 manual conversion?
    Peugeot 206 Auto convert to manual?
    What's involved , anyone done it here?
    I have a manual car that's a write off, so i have all the bits.
    Does the flywheel bolt up to the 1600cc twin cam auto engine and the auto just unplug the elecs?
    Presume clutch pedal fits in, clutch pedal looks very fiddly to get in place?
    The gear linkages , do they fit on the existing sub-frame or is this going to be a problem area?
    I have two dead cars here maybe i can make one good car rather than have two cars which are scrap. The donor is an insurance write off, the slightest amount of damage. An absolute waste.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,446
    Have a look around this site, someone here in the last 6 months was converting a 306 cab auto to manual.
    Edit: Was PugMonkey
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Jerangle
    784
    I have already done a 306 conversion but i think the 206 has it's own special set of problems.
    Don't remind me!
    16,609
    The only way I can think to have a go at it, is to work from the VIN of each car, where there is a question mark look at whether the part numbers are the same or compatible.
    Subframes are commonly removed on 206, this is not a big deal - leave the rack dangling, or tie wire it up while you work. Probably simplest to remove subframe, drop powertrain out the bottom, reconfigure then lift up into the car. You will have to reconfigure the BSI to manual trans, and dummy a few wires that used to reach the transmission ECU.
    Jerangle
    784
    Addo,
    what about i just swap the whole lot, subframe engine /gear-box and change all the ECU/BSI/locks from the donor car ?
    Then there should be no need to configure?
    What happens with the auto wiring, can the loom just sit there after the auto ECU is unplugged, is there any need to do anything then?
    With the car it is not worth spending money on it with another gearbox, i need to either cut my losses very soon or convert it . Already it has taken up far to much time.
    Fellow Frogger! Ikenna351's Avatar
    Abuja, Nigeria.
    297
    Converting a Peugeot car from auto to manual transmission is very was and simple.
    You don't have to swap the electrical parts. Just unplug the auto components not needed anymore. If its AL4, locate the starter wire on the multifunction switch connector, bypass and take it to the starter solenoid.
    Ikenna, the Lion King
    Jerangle
    784
    Are all the brackets for the 206 gearchange on the auto sub-frame?
    Flywheels interchangeable? Meaning bolt pattern the same.
