504 auto driveshaft removal
  • 1 Post By Beano
Thread: 504 auto driveshaft removal
    Jan 2015
    New Zealand
    32
    Icon5 504 auto driveshaft removal
    I've removed the engine on my 504 but the auto gearbox has the driveshaft still stuck in it and I can't seem to pull it out to allow the gearbox to be removed. Would have thought that it would just have splines on the end and slide out easily but it doesn't seem to budge. Is there a trick to doing this? Gearbox is free and moved forwards, torque tube has been unbolted from rear diff and moved forwards but rear subframe prevents it being lowered.
    Thanks in advance.
    Dec 2005
    HOBART
    1,265
    Default 504 auto driveshaft removal
    I used to separate the gearbox from the torque tube by using a pair of multi grips clamped over the shaft and then gripping the multi Grips tight and levering the gearbox away with a large screwdriver or tyre lever.
    Sometimes takes a bit of work to get it started. You will need to support the tranny so there is no strain on the torque tube, though
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Quote Originally Posted by pugnut1 View Post
    Same system as I have used - works well
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
    1000+ Posts Beano's Avatar
    3,150
    Me too.
    If it's REALLY stuck, step back and look. One of those units will be hanging down and mis-aligning the 2 things you want to separate.
    pugnut1 likes this.
    Jan 2015
    New Zealand
    32
    Thanks for that, it must have been the alignment because after a play around it came out rather easily!
    Current: 205 GTI Mi16
    309 GTI16
    306 GTI6 (Ph3)
    406 HDi Wag
    Project: 504
    Previous: 106 Rallye (S1)
    206 GTI 180
    306 S16 (Ph1), & GTI-6 (Ph2)
    405 Mi16, & SRDT x2
    504GL
    CitroŽn ID19
    BX TZD
    Xantia 2.0
