205 GTI petrol cap but no key
Results 1 to 12 of 12
    brisbane
    2,908
    Default 205 GTI petrol cap but no key
    I have a very good petrol cap [getting rare now ] but it doesnt have a key.
    I would hate to bin/trash it so was wondering if anyone has any ideas/tips ?
    By the way...it is on a restoration car i am doing up.
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    Fellow Frogger! 1pugnut's Avatar
    wollongong
    444
    Quote Originally Posted by jr20516v View Post
    Take it to lock smith with your ignition key and they should be able to key it alike probably cost you $35.00.
    series 2 405 mi16
    205 si
    series 1 205 gti
    series 3 205 with a gti6 motor project
    1970 404 ute 504 ti motor project
    parts cars 2 205 si's 306 sedan
    2004 206 gti180
    brisbane
    2,908
    As mentioned... i dont have a key for it thus i cant remove it from the car :{
    jr20516v
    Now:
    1000+ Posts Richard W's Avatar
    May 2012
    1,357
    Then get a locksmith out to break into it?
    My Supermodel 63-1092's Avatar
    somewhere! Pilbara, Bowen Basin, Melbourne?
    10,867
    Doh!!
    John
    Александър Кристоф Шанел
    tweed heads
    1,503
    Is it possible to remove the filler neck with the cap installed ,,then take it to old mate to get a key cut , if its on a resto you are going to have to remove it one way or another ,dont cherish having to drill the lock out with the tank full of gas it may come out in a rush , not to mention singed eye brows ,douse the neck come out from the top or bottom and are the mounting screws accessible with the cap on pugs
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    brisbane
    2,908
    Yep, thought about that....... it will be the way to go if nothing else comes up....
    .Pugwash....thx for the "think outside of the square" idea....exactly what i was referring to in my initial post ... i will give it a try !!
    A sensible answer sure beats "doh"
    jr20516v
    Now:
    Fellow Frogger! blahblah's Avatar
    Perth
    314
    Hi,
    Ahem, given its your own vehicle I'd suggest you have a crack at picking the lock... You may be disturbed by how easy it can done! The jiggle technique is crude but you could use either a similar petrol cap key (you should be able to see if it's single / double sided key) or a Bobby pin with a second thin flat blade bent at right angles (or thin, small flat blade - don't have to bend) to apply a light twist to the lock barrel. Jiggle the Bobby pin against the lock pins with the aim of having them catch in the release position due to the twist applied. It's all about feel.
    Or get a mobile lock smith to do it for you :-)
    Disclaimer: I do not condone this on anything other that your own belongings/locks and it's at your own risk! Google is your friend...
    1000+ Posts Peter C's Avatar
    SWOTR
    3,657
    Hmm, okay but I wonder how he knows how to do this?
    brisbane
    2,908
    Thanks for the reply blahblah.
    Yep, have tried all those tricks before posting and tried the stash of PUG keys i have accumulated after owning some 24 of the little buggers.
    Just thought there may be some odd thing i havent thought of but it appears not so.
    Unfortunately may have to go to the last resort....the dreaded mobile locksmith:{
    jr20516v
    Now:
    Perth
    314
    Ah well worth a shot - if you weren't over the other side of the country I'd volunteer :-). At least you'll get some keys for it with locksmith.
