I know other people have had problems with these, so hope some of you have suggestions:
It’s a D9 (2001, not CANBUS) and it’s an SV (shouldn’t be relevant).
The problem is that when I press the remote button, all door locks (& the boot lock) make locking noises, then immediately unlock again!! It all worked perfectly when we bought the car a couple of years ago!
The handbook tells me that “If one of the front doors is open, the central locking does not work”. So I shouldn’t need to test the back doors? What about the boot? Is it definitely not monitored?
So it seems the system thinks one of the front doors is open, no matter how carefully I close them. So what is the mechanism that decides if a door is open – it appears to be different to the device that turns the lights off when I close the door, as this appears to be working normally...
Alec
