bosch ignition fly lead
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    Default bosch ignition fly lead
    Fiche pratique moteur/Réparation fil signal d'allumeur BOSCH - L'Injection LE2-Jetronic BOSCH
    so im trying to remove the crimped connectors from this plug, ive gotten the clip held together by glue, now im just trying to remove the crimped connectors. i know that every crimped connector has its own way of fitting but mine are not coming out of this plug
    they look like a standard pushon but i cant seem to unlatch whatever it is thats holding it in. i've tried inserting practically everything in there already
    from the image on that french site it doesnt look like anything hold on to them, and from what i can see on my lead the ends of the crimp look the same, so im pretty sure the whole crimp is the same.
    any ideas?
    19,211
    There will be a "tab" on the rear side connector. The stab sticks out and engages a "ridge " in the plastic housing.
    To remove the connector from the housing you need to flatten the tab.
    Jan 2013
    1,675
    ok i was in deep enough but wasn't thrusting the flathead down
    got it out without damaging too much
    thanks
    19,211
    The best removal tool is a sacrificial table knife. Grind the blade to 5.5 mm width.
