306 Starter motor removal
Results 1 to 9 of 9
  • 1 Post By TrinityJayOne
Thread: 306 Starter motor removal
    May 2014
    Strathpine
    8
    Default 306 Starter motor removal
    12/97 Built 306 XSI, 2 litre, auto trans. Thanks to this forum & others, I found the 3 bolts under the air box ,through the bell housing that secure the starter motor .
    Are there any tricks/advice/ ideas to get the wretched thing out?
    I have the bolts out, and the starter is loose- I can move it about 10 mm, but thats it. Do I need to remove the intake manifold or radiator?
    All tips/ideas/rants/theories will be considered. Help!!
    I'm no idiot with cars, but 306 starter motors are new to me.
    Thanks in advance for all replies.
    1000+ Posts Peter C's Avatar
    SWOTR
    3,660
    This probably doesn't really help, but with a 406, you need to remove the air box and also the coolant hoses. Once done, you can manouevre it out via the space created.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,446
    Just had a look at my starter motor 1998 Xsi only the 3 bolts hold it in. You may have to undo the power cables 1st. Treat it (a bit) roughly, shake the end opposite the bolts up and down whilst trying to move it to your left.
    Good Luck
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    May 2014
    Strathpine
    8
    Got it out! What an uninspired, stupid design to make a simple task way more difficult than it should or even needed to be.
    Don't get me wrong, the 306 is a great car, but things like this **** me off.
    Rant over, and thanks for all assistance.
    SWOTR
    3,660
    I hear you, brother.
    Mar 2011
    413
    Quote Originally Posted by Webby View Post
    Best not look behind the left front wheel on a GTi6 then...
    Codman likes this.
    2000 306 GTi6 'Josie'
    Dec 2005
    HOBART
    1,265
    Quote Originally Posted by TrinityJayOne View Post
    The early 8 valve 306 starter was so easy to pull out too.
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Apr 2005
    866
    Your lucky it's not an S16 pictures with and without the inlet manifold... definitely won't come out with the manifold on!! Sometimes you just have to take a bunch of stuff off to do the job you need to, I've learnt that it's quicker to just remove everything that is in the way . I changed the left radiator fan motor on Sat. Bumper off wasn't enough, also had to remove the slam panel to make enough room to get a 10mm socket on the back side of the motor mounts
    Tony.
    Attached Thumbnails Attached Thumbnails 306 Starter motor removal-20150202_143700.jpg   306 Starter motor removal-20150201_144139.jpg
    306 S16 1995 black
    Morris 1100 1965 green
    SWOTR
    3,660
    We did think about removing the inlet manifold on the 406. Would've have given easy access to the starter. Didn't though, lots of pipes and stuff.
