Timing belt intervals.
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By TroyO
  • 1 Post By HONG KONG PUGGY
Thread: Timing belt intervals.
    May 2014
    Strathpine
    8
    Default Timing belt intervals.
    The owners handbook says to change the cam belt every 80,000 Km. I haven't found a time limit, just the distance mentioned.
    Ours was was replaced 70,000 KM & 9 years ago. Time to replace on time alone? Or leave to 80,000.
    I'm inclined to get it replaced, ( because I worry about such things)
    Thanks for all replies.
    Sep 2012
    Central coast NSW
    54
    If they are only giving you 80K then wait until then, usually it's 100K so yours is conservative anyway
    1000+ Posts Peter C's Avatar
    SWOTR
    3,660
    I, too, was under the impression that a time limit is stipulated for timing belt changes, and 9 years sounds like a mighty long time.
    I'd change it regardless. Better than it suddenly letting go and causing damage.
    1000+ Posts TroyO's Avatar
    2,511
    If the last was done 9 years ago I would probably get it replaced.
    4 Years / 80000km is the usual interval for timing belt changes on Pugs.
    HONG KONG PUGGY likes this.
    Nov 2002
    Yarrabilba, Queensland
    2,759
    Yes, I would change it as most manufacturers state 4 years if I recall right.
    Some, like Renault give 100,000km, Peugeot/Citroen the 80,000km.
    I do my Scenic every 4 years or close to as the damage is well above 3 times the cost of a belt replacement if it does go.
    Kim Luck likes this.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    May 2014
    Strathpine
    8
    Thank you all for your advice. I'll get it done. After I sort the started motor out.
    Jun 2011
    Tasmania, Australia
    218
    Quote Originally Posted by Webby View Post
    4 years / 80,000klm for the petrol motors, and don't forget the water pump and belt idler and tensioner pulleys together with seals if required. Usually the alternator belt, idler and tension pulleys are stuffed as well!
    Do a proper job to avoid later dramas down the track
    Alain
