AL4 fill plug
Results 1 to 15 of 15
Like Tree3Likes
  • 2 Post By Balki
  • 1 Post By jb007
Thread: AL4 fill plug
    Aug 2015
    adelaide
    40
    Default AL4 fill plug
    im about too service the auto trans, I need a 8mm square male socket, no one stock them in Adelaide so I must get it off ebay ..MY question has any one used the ones coming out off china??? sometimes cheap equals shit. thanks
    8,226
    Icon3
    Quote Originally Posted by loopie View Post
    I used a short extension and ground the male end down to 8mm square - a bit naughty but works a treat
    08 C5 X7 HDi very Noir
    5,260
    or get a square rod they use to make keys out of and grind to size
    "The enemy of knowledge is not ignorance, it's the illusion of knowledge"
    Stephen Hawking
    8,226
    Quote Originally Posted by JoBo View Post
    The fill plug is a fair way down, you need a 300 - 400mm extension to reach, the short extension is perfect for the job.
    For the same reason, loopie will need a length of tube fixed to a funnel to fill . . .
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,445
    Isn't 8mm square same as sump plugs (Renault).
    I got a Kincrome socket in a small set, they may be available separately?
    Good strong socket.
    Cheers.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    Don't remind me!
    16,609
    I bought them out of the UK, I know Australdi has a spare that she may sell if French Connection don't have any.
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    631
    grind a cheap chinese extension arm works a treat or use a cut of peice of allen key then grind it square on one end and then fit it to a small socket to turn it
    forumnoreason and Berridale like this.
    Aug 2012
    Gold Coast
    51
    Some of the sump plug / oil drain plug kits available at most auto parts shops Repco, SCA, Bursons etc will have an 8mm and or a 5/16" Sq drive that will suit. the entire kit costs about $35 from memory.
    Member jb007's Avatar
    Aug 2015
    Altona Meadows, Victoria
    96
    If you haven't already found or made one, I got this from Supercheap Auto.
    Jim
    GreenBlood likes this.
    2017 Renault Clio Expression 1.2l
    2002 Peugeot 206 XT 1.6 Manual
    http://www.jims-blog.com
    Aug 2015
    adelaide
    40
    Icon14
    Quote Originally Posted by jb007 View Post
    Jim
    thanks buddy I didn't look in supercheap, ill drop in today and look at them, other wise ill get the draper one from uk
    Mar 2011
    Linton.Victoria.
    1,239
    Piece of 8mm tool steel from your local bearing service-OR the sq. shaft from a door handle set.
    Fellow Frogger! renoamust's Avatar
    Jul 2012
    Moss Vale NSW Australia
    126
    Dapco or Caravelle have them to suit 1/2 in socket bar not real dear and they can post it to you get some plug washers at the same time
    Mark C.
    Jun 2012
    Port Macquarie
    56
    Hi get yourself a large screwdriver check that the shaft is 8mm and cut of the blade of the driver, use a spanner to start to undo the plug and just use the screwdriver to finish undoing the plug.
    Cheers.
    Aug 2015
    adelaide
    40
    Quote Originally Posted by The Fixer View Post
    Cheers.
    all done I brought a set from super cheap, I brought the oil from a trans shop
    158
    What Jobo is referring to is called 8mm key steel and is freely available from any engineering supplier , just buy the length you need
