604 Electronic Dissy
Results 1 to 9 of 9
    Hobart
    1,496
    Hi,
    I am after some advise on the 604...
    I have a Volvo dissy to go in it, does anyone have a wiring diagram so I can wire it up into the 604 ??
    Any help would be great
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    12,266
    as soon as i get around to fixing the doors on the 604 so i can open them up again i'll draw up the diagram
    some #^$hole decided they wanted to try and get into the car to steal the battery out of it but instead stuffed the lock
    and seeing as i haven't put the grille back into the GTi-6 yet the same decided they might try and take my battery untill something spooked them
    i went to start the car this morning and nothing lit up
    i thought that's weird
    popped the bonnet and the battery cover was sitting in front of the car and the positive terminal was off the battery
    have no fear though as i know the culprits and have since been dealt with in true pugrambo style
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    9,223
    And now you're out of milk, right?
    12,266
    always plenty of milk here
    shame today was cool
    1 x 2018 3008
    Hobart
    1,496
    They are sure about !
    They have some need to try and steal my sisters 504 TI at the mo.....who knows why it's not a Commondore with wide wheels!
    Anyhow thanks Sean....I look foward to finding out! I have been told that the elextronic dissy will make the 604 a much better car!
    Ben
    1973 Peugeot 504 GL
    Fellow Frogger! MR604's Avatar
    May 2002
    Bathurst
    946
    pugrambo:
    Would you be able to send a copy of the wiring down this way too thanks deal
    cheers!
    A computer lets you make more mistakes faster than any other invention in human history, with the possible exception of handguns and tequila. - Mitch Radcliffe
    Mar 2003
    Tasmania
    1,419
    Ben, my car has the electronic dissy, so if you want to come up and look at it and take some notes you are welcome.
    You know where I am.
    Pugs Rule!
    403, now sold
    404, project
    12,266
    thought i might as well post this in here as well
    maybe a how to section could be an addition to A/F with pics and procedures for people
    or do we already have one ?
    just a thought
    click here for some pics
    now then
    from the volvo control box there are 4 wires you need to worry about
    at the end of the wire loom from the box there is a white wire and a brown wire
    white wire goes to negative side of the coil
    brown wire goes the positive side of the coil
    not far from the end there are another two wires that come out of the volvo loom from the control box
    the blue wire goes to 0.4 side of the ballast resistor
    the brown wire goes to the 0.6 side on the ballast resistor
    these are both one one side of the ballast resistor
    the other side of this you need the yellow wire number 24 from the pug wiring loom
    wire number 112 from pug wiring which is green goes to the negative side of the coil and 112A is blanked off also the bigger blue wire that comes out of the loom next to 112A is blanked off as well
    you should have a wire from the dissy that has a plug on the end of it with a spring clip on it that one of course plugs into the the other wire from the volvo box
    if you need any more help just let me know and i can walk you through the process
    now then when you go to put on you electric fuel pumps run the positive wire from the positive side of the coil
    that way the pump only runs when you have ignition on
    you can run a fuse on there as well to safe guard it if you like
    make sure you also put a "T" in the return fuel line with restriction to run any excess fuel back to tank
    you can blank the line off if you prefer but i don't do this
    if you leave it dangle fuel will run out of it
    if you leave it plugged onto the old pump it will pressurize the fuel tank
    1 x 2018 3008
    Hobart
    1,496
    Well the 604 is fixed!
    Turned out to be a missing tappet! it had broken in half and was laying around near the OHV Gear
    So she is all good now!
    Ben
    1973 Peugeot 504 GL
