Front driveshaft torque 405 mi16
Results 1 to 12 of 12
    Mar 2014
    108
    Default Front driveshaft torque 405 mi16
    Hi, can someone please check their Haynes for the 405 and let me know the front driveshaft nut torque please?
    thanks,
    geoff
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    As tight as you can
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Quote Originally Posted by mi16pug View Post
    thanks,
    geoff
    405 Diesel (Would a non Diesel be any different??)
    Models up to November 1992: 265 Nm 194 lbf ft
    Models from November 1992:
    Early solid type hub carrier 320 Nm 235 lbf ft
    Later hollow type hub carrier 325 Nm 240 lbf ft
    972
    I was going to guess around 200 Nm, which is the spec for the Subaru I just did. Those numbers are somewhat higher, you're going to need a big torque wrench.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, AT Power Dry Sump, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, Custom Radiator and Oil cooler, 3J Plate LSD, E85.
    Sandown - 1:31.5, Winton - 1:40.2, Wakefield - 1:11.05, Phillip Island - 1:55.9, The Bend (International) 2:23.2
    7,513
    Or a 35mm impact socket welded to 1m of RHS.
    1000+ Posts driven's Avatar
    Apr 2005
    1,514
    With about 33 kg pushing down get approx 240 ft lb
    torque wrenches are more accurate
    972
    I don't know about that. Your mixed unit calculations seem very accurate.
    1000+ Posts Peter C's Avatar
    SWOTR
    3,732
    How about a friend weighing 240lb standing on the end of a 1 foot bar connected to a 35mm socket?
    Perth
    727
    Quote Originally Posted by Peter Chisholm View Post
    That would be a tad over 109Kgs on the end of a 30.48cm bar - but the force must be at the very end point!!!
    SWOTR
    3,732
    Quote Originally Posted by Roland View Post
    Yeh, I know. You'd have to allow for that in the bar length or find a very large ballerina who can balance on her toes.
    Apr 2014
    Orange
    378
    26.5 kg-m = 259.876225 Nm according to the French 405 manual once I worked out what the hell they were talking about.
    7,513
    I taped a bertie beetle clicker on the end so I know when it's there.
