505 rear coil springs removal
Results 1 to 18 of 18
    Feb 2013
    israel
    822
    Default 505 rear coil springs removal
    hello
    i'm going to replace the rear springs.
    haynes says drop the final drive onto the cross-member. how is it possible if the torque tube is attached to the gearbox?
    and what bolts (ie size and pitch) should i get to screw through the plug under the rear seat instead of the tommy bars?
    thx
    Our most Southern Member (Tas)
    277
    Independent rear end or a solid one ?
    Feb 2013
    israel
    822
    Sedan, independent axle.
    1000+ Posts Beano's Avatar
    3,142
    Why are you replacing them, 2pac ? I've never known 505 rear springs to sag, though 504s were notorious for it.
    And when I replaced my 504 ones, I regretted it....the rear was much harder. I should have used secondhand 505 ones.
    Feb 2013
    israel
    822
    My 84 car has a very high rear end and the body is inclined, which doesn't look too good. I got me a pair of springs from a 88 whose rear end was much lower than mine, and the body was horizontal. they are marked in different colors ( blue instead of red or yellow).
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    547
    To remove the rear springs you must swing the trailing arms down a long way .
    To do so , remove drive shaft , disconnect sway bar from trailing arm , remove rear shock .
    Then loosen the bolts on the front of the arms , swing arms down and remove spring.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Feb 2013
    israel
    822
    That's one option. I did it this way in a car I was breaking and i needn't loosen the pivot bolts of the arms, I just don't want to mess with the drums.
    Pearl Beach NSW
    547
    Quote Originally Posted by 2pac View Post
    If you dont want to mess with the drums , remove the exhaust , unbolt and remove the diff from back of torque tube and lower the arms together, this will allow you to get the springs out
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Feb 2013
    israel
    822
    If i remove the shafts from the diff, what sort of grease should i apply on the splines when inserting them back in?
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,439
    The diff oil should lubricate them.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Feb 2015
    91
    The rear of my 505 GTi sags as well. The ride is harsh and I suspect the springs and shock absorbers are aftermarket replacements. Thanks to all for the suggested replacement methods.
    I will look for original Peugeot springs and, perhaps, modern gas assisted shockers.
    One trusted mechanic suggested fitting springs from the diesel models to my petrol version.
    Worth looking into.
    Feb 2013
    israel
    822
    Do you want my old springs?
    3,142
    As BigRR says : the diff oil.
    And just in case you are unaware, the drive shaft outer splines and both prop shaft splines are best lubed with Molydenum grease.
    Feb 2015
    91
    Could be interested if the springs suit my 1985 series II GTi. Please sent details; cost, shipping etc.
    I am gradually improving this car, but prefer original parts if possible. Thanks for your interest.
    Feb 2013
    israel
    822
    Quote Originally Posted by Beano View Post
    the manuals say use molykote 321 dry film for the outer splines. when the garage replaced my driveshafts gaiters they didn't lube them with nothing.
    for the propeller shaft splines, haynes says "grease", and an online 504 guide says "multi purpose grease H", which is just a general grease.
    anyway, i'm going to do that this morning in the method of disconnecting the diff from the propeller tube, and i bought this grease for the propeller rear end splines.
    http://www.conrad.com/ce/en/product/...e-grease-400-g
    Feb 2015
    91
    2pac, yes am interested in springs. Please send details. Thanks.
    Dec 2011
    Athens, Greece
    299
    Quote Originally Posted by jacques de mort View Post
    Worth looking into.
    The rears are the same for the diesel models. The fronts are different because of the heavier Indenor engine. There are plenty of up-rated rear springs available in OZ for the 505.
    Feb 2013
    israel
    822
    message sent.
