BE1 end cover & filler
Results 1 to 3 of 3
    Mar 2014
    108
    Default BE1 end cover & filler
    Hi all, two questions:
    Q1. believe that the 19mm head bolt in the BE1 end cover (in passenger side wheel
    Arch) is the filler hole for the BE1. Can I instead remove the plastic 'bung' which is on top of the box to put 2L of oil in using a funnel
    Instead?
    Q2. If I removed all the bolts of the end cover of the BE1 (accessed through the passenger side wheel arch), what is under there? Is there gearbox oil in there or is it just a cover plate? Reason I aske is that the seal around all the bolts looks wet/damp and wondering if it needs re-sealing.
    Let me know,
    Geoff
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,441
    Quote Originally Posted by mi16pug View Post
    Instead? Yes may be filled from plastic bung hole (Breather) Note place gearbox in reverse gear 1st.
    Q2. If I removed all the bolts of the end cover of the BE1 (accessed through the passenger side wheel arch), what is under there? Is there gearbox oil in there or is it just a cover plate? Reason I aske is that the seal around all the bolts looks wet/damp and wondering if it needs re-sealing. 5th gear. I think oil will run out!
    Let me know,
    Geoff
    Good Luck.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Mar 2014
    108
    Great! Thankyou
