Pug 207 - engine management system faulty
Results 1 to 15 of 15
  • 1 Post By blink
Thread: Pug 207 - engine management system faulty
    Dec 2010
    232
    Default Pug 207 - engine management system faulty
    Hey all,
    Latest fault on the pug displays the message in the title.
    I've noticed that while the warning light is on, the air con stops working, every now and then the warning turns off and air con blows cold air again.
    Only seems to be effecting the air con, car runs and works as it should.
    Any ideas ?
    Dec 2010
    232
    So it seems the failed part is the electronic thermostat. Fault code suggests its gone open circuit.
    Enlighten me sometime, are thermos controlled electronicly these days?
    And what do I need to replace exactly? I suspect it is all built into a housing and it all goes into the bin....
    What a pain! At least it's gone Cactus in the open position as temperature never exceeds what it shouldn't...
    Sep 2003
    North Parramatta
    3,997
    Yes, your suspicions are correct - it's an all-in-one unit that needs replacing.
    There was a thread on the Citroen forum about a DS3 with the same item. It's not that cheap.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Jul 2012
    160
    Might be cheapest to source thermostat from overseas. Try a mob called Eurocarcare who are in the UK. They have access to genuine pug and citroen parts which are considerably than Aus dealers. Just order a chrome mould from C5. Aus dealer price $274. Eurocarcare was $114 shipped!
    Dec 2010
    232
    Part is a 145 plus gst from EAI. Sounds reasonable enough to me.
    Since the fault code suggests specifically an open circuit and the fault did come and go initially, will check the terminals for a bad connection first....
    Thanks for the input
    19,211
    Quote Originally Posted by blink View Post
    Pull it apart and have a look.
    You may find a cooked resistor or bulging capacitor. Or a relay (if it has one on board) with toasty contacts.
    You have nothing to loose.
    Don't remind me!
    16,609
    Hi Rob, it's not always so easy; check out this picture for an idea:
    GENUINE CITROEN C3 DS3 PEUGEOT 208 1.6 PETROL ELECTRIC THERMOSTAT HOUSING 1336CE | eBay
    19,211
    OK, thanks, similar deal to VAG. Three stage cooling system.
    I had in my mind an aircon thermostat.
    As you were and thanks for the lesson.
    Dec 2010
    232
    Ok, part replaced and when scanning the ecu for faults it comes up with nothing which is great. Also, ac, cruise control and all that are up and running again...
    One annoying thing though, even though I cleared the ecu of all faults, it still displays "engine management system faulty" upon start up on the dash together with permanently lit triangle/!
    Any ideas ?
    Sep 2003
    North Parramatta
    3,997
    What scanner are you using?
    Most generic scanners have a function to reset the "check engine" light or "MIL" light (as the US likes to call it). This is different to clearing faults.
    Simon
    Dec 2010
    232
    Ah ha, I'm just scanning with an Android app over a blutooth obd plug in thing.
    I'll see if it has such a function....
    Sep 2003
    North Parramatta
    3,997
    It's also possible it's one of those faults that needs multiple "good" restarts in order to clear the check engine light.
    Simon
    Dec 2010
    232
    Legend mate! Problem solved, just had to find the right app.
    Don't try this job at home If you got humongous hands is all I can say !
    Unfinished threads pee me off when looking for info so here's pics of the old part for future reference. Comes complete with coolant temp sensor and set me back $145+gst from EAI (for a gti).
    They had a variety for 207's ranging up from $105+gst.
    Dealers wanted $150 to scan the thing then labour and parts cost on top. Took me like 2 minutes to pull the fault code with a phone! What's that....hang on...$4500 an hour, yep
    Beer o'clock
    Thanks all.
    Attached Thumbnails Attached Thumbnails Pug 207 - engine management system faulty-uploadfromtaptalk1427508703440.jpg   Pug 207 - engine management system faulty-uploadfromtaptalk1427508730124.jpg   Pug 207 - engine management system faulty-uploadfromtaptalk1427508931777.jpg
    SLC206 likes this.
    Jan 2015
    ACT
    62
    Well done, I love this forum.
    Dec 2010
    232
    Quote Originally Posted by SLC206 View Post
    gave it about 10 goes then called it lunch time, read your post, found an app, back to the car, key on, engine running, flashed the message at me again, stuffed around with the app, and it turned off after a couple of minutes.
    Not sure weather it was the app or not anymore tbh, but its fixed !
