306GTI6 renewal and update time
Results 1 to 15 of 15
  • 1 Post By BIGRR
Thread: 306GTI6 renewal and update time
    Fellow Frogger! dhaw's Avatar
    Feb 2005
    SYDNEY
    529
    Default 306GTI6 renewal and update time
    I'm a whisker off 300K in my 99 GTI6. Still on the original clutch. So I was thinking when it visits the workshop for the next cam belt change it might be clutch time and rebuild time. Question is when rebuilding a 6 engine are there warmer options available in Australia for new cams or must I import form the UK? I'm starting to question my ride quality but its hard to assess. Has anyone replace the front shocks? What have you used and are OEM shocks still available?
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,370
    Cams are available. You can potentially piggyback the ecu to cope. PeterT cams are the way to go.
    A lightweight flywheel will help and is a nice upgrade while its apart.
    Can comment on the shocks. Whos rebuilding it?
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Feb 2005
    SYDNEY
    529
    The Colliers at Granville are my trusted repairers and have motorsport experience. Fly wheel tip is a good one... I had not considered that!
    Nov 2003
    Bondi
    3,370
    Ok great. Do they have experience with the RS motor?
    Ttv flywheel is the one you want. They are 3.2kgs and work fine with a standard ecu.
    Cam
    91 205 Si
    87 205 GTi Race Car
    Feb 2005
    SYDNEY
    529
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    For a standard clutch (215mm) you want Part No-0686, 3.8kgs. Ask him to supply 6 x M7 pressure plate bolts as well. You need to drill the holes in the pressure plate as the standard ones are M6.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Nov 2003
    Bondi
    3,370
    Yep, thats correct. My bad. Thanks Jeff
    91 205 Si
    87 205 GTi Race Car
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    300k on an original clutch? That is very impressive
    is that typical? or do you drive it easy
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,441
    I would say Lots of 6th gear work!
    lion5 likes this.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Apr 2005
    866
    My S16's clutch was down to the rivets and slipping (though the main oil seal leaking was not helping there) at ~240,000KM. If you have done 300,000KM on the original shocks then I would think that they would be tired. I replaced mine at around 165,000KM and noticed a big improvement. The thing is they degrade slowly so it is hard to pick up on it. I started to notice the car being a little more prone to undulating on certain roads.
    I just checked service box and front and rear shocks are still available for my S16 so they definitely should be available for the six. I believe the replacement part listed (original S16 part is not available any more) is actually the Gti6 part.
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    Feb 2005
    SYDNEY
    529
    Thanks Tony... front only? Rough cost?
    David
    Feb 2005
    SYDNEY
    529
    I thrashed my 1997 car and needed new clutch at 155K. This 1999 one still gets the odd caning but has done a lot of sixth gear work with the cruise on!
    Feb 2005
    SYDNEY
    529
    Default A bush car!
    A wee piccie while storm chasing 306GTI6 renewal and update time-storm-chasing-sml.jpg
    Fellow Frogger! SilverGTi_6's Avatar
    Apr 2005
    849
    Cool pic!
    Lotus Evora
    Peugeot 308 GTi
    1966 Volvo 122s
    Clio Sport Cup 182
    Previous
    Lotus Sport 111, C4 VTS, RCZ, 205 GTi, Volvo C30 T5-R, Honda S2000, 206 GTi180, Lotus Elise 111R, 205 GTi 6, Manual 406 coupe, 306 GTi 6, 405 MI16 (twice!), 505 GR
    Nov 2003
    Bondi
    3,370
    Great shot!
    At thise kays i would also inspect the rear beam. Just a thought
    91 205 Si
    87 205 GTi Race Car
