Rear Wheel Alignment for 504 Rally Car.
Results 1 to 7 of 7
  • 1 Post By Douvrin504
Thread: Rear Wheel Alignment for 504 Rally Car.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    548
    Default Rear Wheel Alignment for 504 Rally Car.
    At the tyre shredding Jenolan Rally my rear tyres were wearing out the inside edges leaving the outer edges almost brand new.
    So I was thinking it would be a much better car if I could even out the wear across the tyre .
    My first thought is to change the rear wheel toe-in. The 504 does not have any toe adjustment , so I am going to machine the rear wheel bearing carriers, the question is how much toe-in should I aim for as need to decide before sacrificing a wheel bearing carrier.
    The camber is about 2degree negative and stays fairly constant thought the working range of suspension travel.
    What settings do other cars with similar trailing arm suspension use?
    What is best for traction ?
    What would be best or worst for stability at speed
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,444
    Have you bent the rear beam? I think I have heard of them bending.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Dec 2002
    CANBERRA
    400
    Hi Andy, you can't see what I'm doing with my hands but are you sure it isn't caused by too much neg on the rear rather than toe? As BIGRR suggests is worse as if the beam bends down in the middle I think Thanos puts a fillet of flat in the beam to keep it stiff.
    Jim
    9,280
    2 degrees is definitely more than standard and yes, they do bend.
    Quote Originally Posted by pug303 View Post
    Jim
    Dec 2002
    CANBERRA
    400
    2 degrees doesn't sound a lot to me given how a 504 squats but I'm surprised it stays the same throughout the travel as I thought they got more neg the lower down the rear was?
    The rear of the Pathfinder is very subject to camber and will wear an edge, particularly with a bit of positive. When it has a bit too much toe, in or out, it seems to wear across the whole tyre rather than on one side.
    9,280
    Very close to straight trailing arms rather than semi trailing as in BMW, Commodore.
    Sep 2011
    Stockholm Sweden
    126
    I usually adjust camber on 504, using shims in the appropriate thickness, on the 4 screws, it is possible to adjust toe-in with it too.
    It only takes a few minutes on each side.
    BIGRR likes this.
