405 Brakes Sticking
Results 1 to 12 of 12
  • 1 Post By philipjh
Thread: 405 Brakes Sticking
    Don't remind me!
    16,609
    Icon7 405 Brakes Sticking
    Weird one here, gents.
    Have had the car laid up for quite some while, freed the rear calipers by winding the pistons in, cleaning and greasing the slides. Seems pretty much normal except when you try to drive, it is clearly dragging on the brakes! Haven't changed the ride height or adjusted the handbrake cables.
    I'm thinking the booster is pulling on a bit - has anyone seen this phenomenon? Going to play with removing the vacuum line, and also see if there is a preload on the master cylinder (master not that old, brake flex lines all PTFE braided). Non-ABS, diagonally split brakes.
    Cheers, Adam.
    Dec 2010
    429
    Not the short flexible lines collapsed inside not allowing pressure to release?
    Don't remind me!
    16,609
    No, they're comparatively new Goodridge items. The braid (clear sleeved) would be wet with fluid if they'd failed like that.
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    bad piston seal not allowing piston to relax?
    tweed heads
    1,503
    Try cracking the bleeder and see if it stops dragging ,could be something sticking in the compensation valve pugs
    1000+ Posts pgti6's Avatar
    May 2001
    1,624
    Did you jack up the drivers side wheel to open the proportioning valve before winding back the pistons? If not, there may be residual pressure between it and the wheel cylinder which has pushed the piston back out against the disc.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Don't remind me!
    16,609
    I popped a bleeder onto the calipers in turn, created a little pressure with the tool then cracked the bleeder slightly until I had a "head" of fluid in the bleed tube - then opened it more and wound the calipers in steadily before nipping the bleeders shut. I kitted them three years ago with TRW seals, they seemed to not be stuck. Similarly I have also been through the proportioning valve in my ownership and it was mint. Fluid all looked good, compared with new fluid it wasn't discoloured or cloudy.
    What I do remember thinking back, is the first time I pressed on the footbrake after three years, there was resistance, then a "crack" as the pedal moved. It's why I think there is a possible issue with the booster. I'll loosen the master cylinder off, to see if there's preload.
    Don't remind me!
    16,609
    There's a good 2mm preload on the master - not changed since install (not good either, mind). I think disconnection of the vacuum is next to try.
    Is it an utter bastard to remove the booster in-situ without touching the pedal bracket?
    Are there other boosters that fit?
    317
    Had a similar problem with a Mazda 626 my daughter was driving a few years back.
    The one way valve on the the booster wasn't functioning properly and as soon as the car warmed up the brakes locked on.
    Replaced the booster and all was good.
    I think the simple check is to disconnect the vacuum to the booster and see what happens.
    You'll need a bit more pedal pressure but brakes should still pull you up the same.
    addo likes this.
    Don't remind me!
    16,609
    That's just what I did - haven't tested it yet, as it's parked in.
    Really annoys me, because it's an incredibly simple system on this car!
    Don't remind me!
    16,609
    Quick test, booster vac line plugged and no more dragging. Yay, plus a grumble at the R&R now required!
    Don't remind me!
    16,609
    A bit like the old TV adverts: "Wait! There's more!"
    Yes, booster was stuffed, I bought one from a "Fellow Frogger" and refurbished it (documented elsewhere on the site).
    However, upon dismantling to R&R the booster, I discovered the (PBR) master cylinder was totally stuffed! It's only five years old, too. It had shaft corrosion so bad, it was frequently sticking when pushed on. I dismantled it for a look-see and one of the seals inside was damaged by foreign matter, not sure whether it was swarf as delivered, or back-flushing allowed some corrosion into the chamber...
    Oh, and the reservoir cracked open from UV damage. Clearly, it's "One of those weeks"...
