Replace Air Flap Plastic Gears with Brass Gears Peugeots 405 - 406 - 605 - 106
Results 1 to 21 of 21
  • 1 Post By PeterT
Thread: Replace Air Flap Plastic Gears with Brass Gears Peugeots 405 - 406 - 605 - 106
    Jun 2012
    Port Macquarie
    56
    Default Replace Air Flap Plastic Gears with Brass Gears Peugeots 405 - 406 - 605 - 106
    The previous post about the Brass Gears, I have found out that, that site has closed down.
    The new site is http://xrms.free.fr/montage_engrenag...atisation.html
    NOTE: There are underlines between montage & engrenages & climatisation!!!!!
    Then click on : REPLACEMENT DES ENGRENAGES PLASTIQUES DES....FREE
    That will take you to the add with pictures and instructions of the procedures.
    The brass gears cost 55 Euros with 6.90 Euros postage. Xavier (the seller) will only accept payment in Euros.
    It took 9 days from the day he posted the parcel, for mine to arrive at Port Macquarie, NSW.
    The unit is now working and should outlast the rest of the car.
    Hope this helps.
    lost
    11,055
    Icon6
    G'day,
    comes up with a French 404 error.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    8,959
    Check out your URL. There is a server at free.fr, but it won't connect on port 80 to xrms.free.fr
    There's an uncommunicative alias.
    7,483
    Will the 404 error fit the 405?
    angru likes this.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,552
    Sorry but no, you will require 405 error for that
    Every day is a good day
    Fellow Frogger! ajpolden's Avatar
    Apr 2004
    Launceston, Tasmania
    291
    Quote Originally Posted by FIVEDOOR View Post
    Now now, that's not allowed
    Current:
    1999 406SV (D8)
    Previous:
    1986 BX19GT
    8,959
    Since he won't talk to us, here is the cache of the site a few days ago -- Remplacement des engrenages plastique des motoréducteurs de clim par des engrenages en laiton
    or, in Googlish....
    https://translate.google.com.au/tran...lnk&edit-text=
    Jun 2012
    Port Macquarie
    56
    Hi there bshould have been an underscore between montage_engrenages_climatisation
    Sorry for the delay but have been away.
    8,959
    Sorry. Nobody home there.
    Member mandc's Avatar
    Gold Coast
    66
    8,959
    That's what I said up there. He's stlll not at home. To read it, use the Google cache. The wayback machine doesn't have it.
    Jun 2012
    Port Macquarie
    56
    Look at edited blog!
    Jun 2012
    Port Macquarie
    56
    For some reason the correct web page has not been written>
    Here it is with gaps so that it appears right all you have to do is illiminate the gaps.
    http://xrms.free.fr/montage _ engrenages _ climatisation.html
    8,959
    Fixer, I fixed it yonks back.
    Either the author has lost his account, or his hosting server won't permit a connection to some IP ranges. A French proxy doesn't connect, so probably the former. For the time being it looks as though we need the cache.
    Downforeveryoneorjustme thinks it is up, but that may refer to free.fr, an ISP.
    Can you see it? If so, who is your ISP?
    PS It used to get 689 visits per month, from links in car forums. There was also some stuff on Solex carbies.
    dig produces:
    xrms.free.fr. 1901 IN CNAME perso153-g5.free.fr.
    perso153-g5.free.fr. 50190 IN A 212.27.63.153
    PPS I can get directory listings for his photo gallery, videos etc, but the server won't download any file there.
    PPPS This gets weird, I got to the site using an o/seas VPN via the above listing! (Not the front door). This time the server replied. It's quite a good site so I printed it to pdf.
    Feb 2011
    Brunswick Heads NSW
    94
    what's so special about these gears, couldn't you modify ones from model trains or slot cars? Those radio controlled petrol cars are pretty big, gears should drive a flap.
    Feb 2011
    Brunswick Heads NSW
    94
    Or pull apart a decent sized old photocopier or printer.
    Gold Coast
    66
    Quote Originally Posted by The Fixer View Post
    Guys....have you even clicked on my url that does work?
    What's missing is...motoreducteur_......sandwiched between engrenages and climatisation
    8,959
    mandc, if you can see it directly, please tell us your ISP.
    The front door (xrms.free.fr) certainly is restricted. It won't even reply to me, even when I used a proxy. To get in, I had to find a page whose URL is below root and enter from a European IP (see above). The server may have a large range of IPs banned. Here is curl, after several minutes timeout:
    $ curl -v -I http://xrms.free.fr/montage_engrenag...atisation.html
    * About to connect() to xrms.free.fr port 80 (#0)
    * Trying 212.27.63.153... Connection timed out
    * couldn't connect to host
    * Closing connection #0
    curl: (7) couldn't connect to host
    8,959
    Here's a development - Opera with the Turbo feature enabled can see it.
    (It enters the site using Opera's proxy server, and returns it to you compressed, for your browser to uncompress and display).
    PS Quality illustrations, such as this:
    Replace Air Flap Plastic Gears with Brass Gears Peugeots 405 - 406 - 605 - 106-screenshot-6.jpg
    Gold Coast
    66
    Can see it on win7 using chrome from telstra isp and macbook using chrome from another telstra isp.
    Sorry guys...didn't realise some were still getting problems with the url I posted
    ps...just tried IE and that is ok as well
    8,959
    Thanks mandc. It is unrelated to Windows or IE or macbook. The curl demonstration above is system neutral. Curl is not a browser.
    The important info is Telstra, as it tells us that many Australian IP addresses have been blacklisted by the French server. It is not restricted to just my ISP either. The Opera turbo server (in USA if memory is correct) also received a good reply.
