xu9ja cam belt for no water pump.
Results 1 to 3 of 3
    1,376
    Default xu9ja cam belt for no water pump.
    Im going a different route with my water pump. I know I have seen someone post up details of making a cover plate for the water pump and getting a shorter cam belt.
    Does anyone know the amount of teeth the cam belt should be reduced to - or the circumference of the belt?
    Thanks.
    Don't remind me!
    16,609
    How do you plan to tension it? Would it be more straightforward to make a dummy cover with a recycled cog on a stub shaft with bearings, for the pump area?
    Jul 2004
    803
    You use a shorter belt addo. Don't forget (im assuming the build you saw was cameron's xu9j4rs on the drivers forum?) that he used a gti6 head so belt lengths may be different. But from memory he used a ford 2.0 zetec belt 120something teeth.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
