205 electrical mystery (help!)
Results 1 to 9 of 9
Like Tree4Likes
  • 1 Post By Wintermute
  • 1 Post By schlitzaugen
  • 2 Post By BIGRR
Thread: 205 electrical mystery (help!)
    Fellow Frogger! lozenge's Avatar
    Castlemaine
    493
    Default 205 electrical mystery (help!)
    my trusty 205 Si is suddenly doing something very strange.
    starts up, drives normally, but the battery light is glowing
    AND nothing but the mechanicals will work, that is the lights
    won't come on, the indicators aren't interested and the windows
    won't go up or down.
    however, restarting the car, first turn of key, everything is as normal,
    lights work, fuel gauge needle comes up, windows and indicators work.
    then start engine and everything else goes quiet.
    what the hell is going on? any advice much appreciated, regards, Lo.
    Apr 2005
    866
    Have you got a multimeter? battery light would normally indicate a problem with the alternator, check the voltage with and without the car running. Should be a bit over 12V with the car not running, and closer to 14V with the car running.
    things not working when the engine is running tends to lead me to think that the alternator is not working and that the ignition is drawing enough current to drop the battery voltage to a level where the other electrics won't work properly, sounds a bit far fetched though, as if the battery was that low I would think you would have trouble turning it over.
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    9,000
    There were comments some time ago that a lot of stuff isn't fused which ends up munching the contacts in the ignition switch. Sure yours is fine?
    Did you measure anything (like alternator running does it give good voltage)?
    The GTI basically has one wire that supplies positive 12V to the ignition switch and that branches out to all circuits via the ignition switch.
    What happens if you want to use something that is supposed to work without the engine running or the key in the ignition (such as lights, brake lights, etc)?
    And before you go any further, check your ground strap to the body, because it may be the one to the g'box/block is good (engine starts), but the other one is bad. Starting the engine possibly just jiggles the body strap a bit and makes it work until next time.
    ACHTUNG ALLES LOOKENPEEPERS
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,439
    crook battery terminal connection?
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Castlemaine
    493
    much thanks Tony, Schlitz and BigRR - I'll have a look in the morning
    and follow up on your thoughts. regards, Lo.
    Castlemaine
    493
    well, did the easiest thing first, tightened up battery terminals... voila!!
    everything now as it should be, so relief for a mechanically-challenged klutz.
    big kiss to BigRR and thanks again to Tony and Schlitz, regards, Lo.
    Apr 2005
    866
    Gotta love it when it is something simple!!
    Tony.
    lozenge likes this.
    306 S16 1995 black
    9,000
    Almost always it is.
    I always cover the negative in some sort of dielectric grease to prevent corrosion and so on exactly to avoid such crap (bad connections to the battery) and try to use decent battery terminals which I can get tight enough to pinch the battery post (some have a few internal ridges that bite in the post). My mistake for assuming everybody else did.
    lozenge likes this.
    Feb 2006
    North Rocks, Sydney
    2,439
    Quote Originally Posted by Wintermute View Post
    Tony.
    Would have to be simple if I got the "big kiss"!
    Wintermute and lozenge like this.
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
