Racing flexible P/S hose - pump to rack
  • 1 Post By Adrian Wuillemi
Thread: Racing flexible P/S hose - pump to rack
    Mar 2014
    108
    Default Racing flexible P/S hose - pump to rack
    Has anyone replaced the MI16 solid line to flexible hose, high pressure power steering line with a flexible hose which goes from pump to rack?
    Reason is that I want an easy way to connect/disconnect the hose line for servicing at the track/rally if required. Also easier to have a simple hose made up rather than having solid line to hose fittings and would free up space around the rack area and get the line away from the exhaust.
    Thought about running a banjo fitting out of the rack to hose, then route the hose vertically (on timing belt side of engine), across the front of the engine back to the pump. Gets the hose clear of heat, but is a longer route.
    Geoff
    NSW
    628
    Done it several time now.
    Used speedflow teflon hose and fittings.
    Cut the end of the original pipe and silver solder dash 8 fittings on
    Adrian Wuillemin
    Mar 2014
    108
    thanks adrian - where did you route the pipework from the rack back to the pump?
    NSW
    628
    The ones I did we're in a 205. Just went across cross member and up to pump on top of gearbox. Used a straight at the rack end and Motorsport connections had a fitting to go into the pump. Went from pump to fitting to 90 degree bend. Worked well
    mi16pug likes this.
    Adrian Wuillemin
