407 SW rear camber
    Aug 2014
    Lismore NSW
    15
    Default 407 SW rear camber
    Hi has anyone solved the rear camber issue? I refer to the fact that it is not adjustable. Mine is out off spec (left -2 1/2, and right -2) and a fast trip to Melbourne and back finished wearing the inside of the tires out.
    Just fitted new Kumo KU31 and don't want the same to happen to them.
    TIA Robert
    Perth Western Australia
    2,694
    Analysis,
    What are the specified figures for rear end? Half a degree variation is nothing.
    Was the wagon overloaded?
    Is the rear end toe-in adjustable?
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,440
    407 Rear end camber SB -1deg 45min =/- 30min.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    6,498
    I agree with Wildebeest, it's more likely to be a toe issue with those camber figures. Out of spec toe imparts a scrubbing action to the tyre and causes rapid wear, assuming tyre pressures were relatively OK of course.
    2003 PEUGEOT 206 GTi
    Aug 2014
    Lismore NSW
    15
    Hi guys, thanks for the replies. Toe was indeed bad,-7.3mm on left and + 1.3 on right. adjusted to +1.6 and +1.5, operator said that would help with the camber, which is now 1dg 53' left and 1 dg 57' right. So camber is now in spec. what do you think of the total toe now at +3.1 mm only toe spec I could find is in degrees(0 dg 17', +- 4').
    cheers Robert
