205 short shift
Thread: 205 short shift
    Nov 2012
    374
    Default 205 short shift
    To those in the know - what is the best mod for the short shift lever with a gti-6 motor with gti-6 exhaust?
    I have seen people have issues with clearance and don't really want to spend money on an after market lever or attachment that won't fit.
    Thanks everyone.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,439
    205 short shift-9036fda9-9bc4-41be-a9d9-7621587464c0%5B1%5D-copy.jpg Cut and shut about 15 - 20mm out of lever shown. PeterT cut 13mm, I think I cut 20mm (20 would be max). I can't see why GTi6 exhaust would make a difference.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,370
    Yep, exactly that. I think mine is 15mm. Its old as the hills. No issues with the 6 manifold on my car. Its close but does not touch.
    I had issues with my gear rods popping off from the heat. A set of miles rods sorted that. If you have not changed them already, the bushes for the L bracket should be replaced, cheap and easy. Its worth doing the one under the gearstick too.
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Nov 2012
    374
    Great, thanks for the feedback guys.
    Nov 2012
    374
    Default I told you so
    Well everyone said to put the short shift "L" lever in before doing the engine swap.
    They said it was easier.
    They said it was worth it.
    Well, everyone was right on both counts.
    It was an absolute pain trying to get the bolt underdone with the gti6 manifold nearby. It was also a pain to re-bend the selector rod to clear the down pipe joint with the new shorter lever.
    But, it's done. And it really is great.
    Less throw front to rear and a much more positive feel to the gear changes. Not notchy at all, just positive, like a modern gearbox setup.
    Thanks again to all for the advice and parts. Happy days! (not doing it again though!)
