V6 extractors
Results 1 to 14 of 14
Thread: V6 extractors
    Jan 2015
    Victoria
    20
    Default V6 extractors
    Hi guys, just wondering if anyone knows if there are extractors you can buy for the es9j4s?
    Jun 2011
    Tasmania, Australia
    218
    Quote Originally Posted by It's French View Post
    Please explain, more information please ???
    Alain
    Dec 2002
    Menzies Creek
    2,541
    The problem you will have is retaining the catalytic converters (x4) and oxygen sensors (x4).
    Removing the first cats causes an error to display on the dash and restricts the engine to a degraded mode of operation. The oxygen sensors after the first cats are expecting an 'improvement' in air quality to the air passing the oxygen sensors before the first cats. Very clever engines.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Jan 2015
    Victoria
    20
    Can you replace the cats after the engine ones with no problems?
    Dec 2002
    Menzies Creek
    2,541
    Yes, the second cats can be upgraded/removed without issue, but probably without benefit also.
    Scotty
    Dec 2002
    Menzies Creek
    2,541
    I should also mention, there is talk of a guy in the UK who has a way to reflash your ECU so that it no longer uses the second O2 sensor readings, eliminating the issue of degraded running and warnings. However, as far as I can tell, he needs the whole car in front of him.
    Scotty
    con
    con is offline
    sydney, nsw, australia
    521
    Quote Originally Posted by Demannu View Post
    This is purely theoretical.
    Oxygen sensors send an A/C voltage to the ECU. The A/C voltage varies depending on amount of (believe it or not) oxygen in the exhaust gas. The first sensor would have a lower amplitude than the one after the catalytic converter.
    To "fool" the ECU it may be possible to simulate this condition (I would even try a DC voltage to start with work).
    Just a thought.
    Jan 2015
    Victoria
    20
    Reason I ask is because my mate is doing a custom stainless steel exhaust system. I don't want it loud, but I would like a bit more performance. I've noticed the es94js is more torquey between 2-4000 revs than the es9j4, but feels as if it has less power over 4000 revs compared to the es9j4. I might be imagining it, but I was thinking a twin 2.5 inch after the engine (from the main flange) with 2 high flow cats and one/two mufflers. Any thoughts?
    Don't remind me!
    16,609
    Nitrous?
    You could readily use O2 dummies and put straight pipe inside your cats.
    Dec 2002
    Menzies Creek
    2,541
    The VVT on the J4S is only active from idle speed (though not while the throttle is closed) to 4520rpm. After that, the camshaft returns to the normal position, and no longer gets any benefit from having VVT. It does however have an improved port design, better injector spray pattern and higher compression than the early engine, but all this is pretty much sapped by the complex exhaust system.
    I think the manifolds and the first cats are the biggest restriction, the second cats look pretty good.
    I have fitted a D8 exhaust system and 'sports' catalytic converter to my D9 engine, between that and the aftermarket ECU, the power delivery across the RPM range is vicious!
    Scotty
    Jan 2015
    Victoria
    20
    So the headers on the es9j4 are the same as the s without those cats? Do you have to get a remap when doing this? Or can you cut the cats out of the s and remap it?
    Basically, I want the most power I can get out of the engine with an exhaust and remap. So how do you get around the cats at the engine in the s?
    Jan 2015
    Victoria
    20
    * remap or aftermarket Ecu
    Adelaide, SA ,Australia
    42
    Default Oxygen sensors
    Re O2 sensors, aren't they just a very sensitive temperature sensor? Only that my old GTi 505 wagon runs much more economically, though not more powerfully after reinstating the Cat with one that wasn't extremely free-flow, ie see thru ! So I thought the O2 sensor which is in front of it could only be seeing a higher temp sooner and thus telling the ecu to run leaner.
    JH
    Currently own '69 404, '72 504 (V6), '72 504 cpe 4cyl (unrest), '74? 504 ti x2, '76 504 auto, '76 504 ti on gas, '80 604SL '81 505(ti) ba10/5 '83 505 (ti) ba7/5 fam,
    '84 505 Sti ba7/5, '86 505 Sli ba7/4 fam (project), 405GRI auto. Too many....
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    There was an episode of Top Gear where James May fitted extractors, exhaust and different intake to one of these engines (in a Renault Avantime) and managed to improved the horsepower at the wheels from less than 160 to more than 190. Basically, after the mods the power at the wheels was the same as the power at the flywheel for the standard engine.
    For entertainment's sake they said they got the engine back up to new horsepower, because they couldn't be bothered explaining the difference between flywheel horsepower and wheel horsepower. They did a similar thing on another episode where they put a number of older hot hatches on a chassis dyno and said they'd lost a heap of power since new, but if you checked the figures, they were exactly what new versions used to get when put on a chassis dyno. 100kW cars usually only get about 70-75kW on a chassis dyno. That's not to say they loose 30% through the drivetrain (more like 15-20%), it's just that the offical power ratings are probably more often based on the initial hand built prototypes, rather than engines off the fully "up to speed" production line.
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
