Multifunction display fail
Results 1 to 12 of 12
Like Tree2Likes
  • 2 Post By pgti6
Thread: Multifunction display fail
    Feb 2015
    NSW Central Coast
    4
    Default Multifunction display fail
    Just discovered your forum today during my searching...great.
    Hoping someone may set me along the right path !
    2008 year 308 XSE HDi Had since new, runs like a dream.
    Woke up a few days ago. and the Multifunction display in the centre of the dash is black, ie no display visible of time/date/temp/radio etc.
    - Do we have a possibly big/expensive problem, or is it just a pullout and replace with another unit ? any guestimate at $ and should I just book it in at local dealer. My local man who does the servicing said would be better off taking to the Dealer.
    Greatly appreciate any advice/comment
    Cheers, John
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,429
    I have no idea of the design of the Peugeot display - BUT - I have come across several other cars with same problem, and it was just the "backlighting" bulbs. If yours is a backlit display it may be similar fault. I think our Renault Scenic is backlit on the central display and I know my previous Ford was.
    What this means is the display is a sort of LCD screen but is made visible by a light shining from behind it, which lights up the characters in the display.
    On one of my cars, I could see the display working if the angle of the sun shining across it was in the right place. Ie, I could see the characters but they were not lit up. Try turning on ignition/radio and shine a torch to reflect across the screen, see if you can see the characters working.
    I merely removed the panel and fitted new small bulb behind the display - all OK!
    So there may be a simple solution, and you may be able to do it yourself.
    Cheers.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    Feb 2015
    NSW Central Coast
    4
    Thanks Fordman, follow your line of thought and just tried the torch, without success, couldn't see any movement in/behind the screen area.
    Looks like a visit to the dealer, in the absence of any other suggestions.
    Cheers, John
    Dec 2005
    HOBART
    1,265
    Sounds like an illumination issue. Have you tried resetting everything? This might just involve disconnecting the battery for 30 seconds or so.
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Feb 2015
    NSW Central Coast
    4
    Thanks pugnut1, is that procedure as literal as you describe ? i.e. disconnect the + ( or - terminal ? ) for half a min. then reconnect and check the result !.
    Is there a downside to me ( as an amateur ) undertaking this procedure, meaning, I know enough to be able to disconnect a battery terminal, BUT upon reconnection if I have a "fail to start" or something similar, then I would really be out on a thin limb...
    cheers, John
    8,930
    Whoa! In your handbook will be the battery disconnection/reconnection procedure. There's usually a wait to allow the computers to compose themselves. The alternative is an insane car.
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    Quote Originally Posted by Fordman View Post
    ***This test should not be performed at more than 80kph!
    pug206gti and Fordman like this.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Sep 2003
    North Parramatta
    3,997
    I don't believe the current displays are backlit using wedge bulbs like the earlier 206/307 designs, unfortunately.
    I think they are LED displays.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    lost
    11,055
    Icon6
    G'day,
    have you looked at the fuse ?
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Feb 2015
    NSW Central Coast
    4
    Quote Originally Posted by pgti6 View Post
    No problem coz I ALWAYS use the speed limiter...
    A bit more searching/enquiries ( including operating the "dark" button on the radio with the engine running and lights on/off) indicate it might be an actual unit failure (yep, checked fuse) which is not a major ordeal to replace.
    Will report back for ors benefit when further progress is made.
    cheers, John
    lost
    11,055
    Quote Originally Posted by jgjt View Post
    cheers, John
    G'day,
    any updates ?
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Jul 2004
    896
    Quote Originally Posted by SLC206 View Post
    I don't believe the current displays are backlight using wedge bulbs like the earlier 206/307 designs, unfortunately.
    Agree.
    I have the same model/year/spec car. Display is dot matrix type led display.
    Going by memory I think they have a dark/no display mode??? Time to read the manual
    Decca
    Present --2016 2008 Outdoor / 2014 RAV4 Diesel (My utilitarian beast)
