I found religion .... I a 306GTI-6!!!! - Page 3
Page 3 of 3 First 123
Results 51 to 56 of 56
Like Tree17Likes
Thread: I found religion .... I a 306GTI-6!!!!
  1. #51
    Orstrayya
    96
    Quote Originally Posted by jr20516v View Post
    errrr.....this is where you lost me... up to then it was believable
    I lost believability at the part where he said "Pac Hwy". How you drive along there without seeing a camera every seventeen metres I do not know.
  2. #52
    Fellow Frogger! acf321's Avatar
    Feb 2013
    273
    Ummm my little secret will stay just that ... and it's NOT the Pacific Hwy!
  3. #53
    Apr 2005
    866
    Quote Originally Posted by Richard W View Post
    Re the flywheel - that's presumably an engine out job so not really fitting Adam's "easy mods" brief.
    No Just gearbox out. But still not easy, and I assume the six is probably as bad (or worse) that the S16! Not something I look forward to doing again.
    Pic shows my S16 engine sans flywheel with the engine still in the car though I just got mine machined and put the original back in.
    Tony.
    Attached Thumbnails Attached Thumbnails I found religion .... I a 306GTI-6!!!!-dsc_0584.jpg
    306 S16 1995 black
    Morris 1100 1965 green
  4. #54
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,596
    I like that fine even oil mist spray covering the block, it really helps to preserve the aluminium block underneath in pristine condition. Mine was similarly preserved, must be a French thing?
    Every day is a good day
  5. #55
    UNM
    UNM is offline
    Dec 2014
    Melbourne, Australia
    321
    A work colleague has just bought a GTI-6 here in Melb.
    Sounds like an exhaust hole in front muffler/resonator. Also has no indication of timing belt replacement and is at about 170,000km. Front tyres a bit worn, but otherwise in fair condition.
    So....
    I assume a timing belt/tensioner/idler replacement is not cheap, but this thread suggests it is likely worth keeping the car alive for a bit longer, rather than just waiting for it to die when the belt goes. Any tips for good/cheap mechanics around the inner East Melbourne suburbs? I could help out, but with four family cars to maintain already, I am a tad reluctant to get involved helping people at work in case I end up with a new full time job. Is the timing belt change straightforward enough? I know the EW10J4, but have no experience of the XU10J4 in the older model.
    If the actual change is easy, I could find parts and suggest he gets a competent mechanic to do the actual install.
  6. #56
    Member givita_burl's Avatar
    82
    I'm going for Peter T cams and Haltech engine management plus bigger exhaust + a thinner Cometic head gasket to raise compression a little + a couple more tweaks that Bluey is doing for me. Pat's engine is similar and it is fantastic.
    Sent from my Q10 using Tapatalk
    What's the change in compression are you looking at?
    Current: 205 GTI, 407 SV
    The Family: Citrun DS3
    For Sale: Megane III
