504 TI Injection problem
Results 1 to 9 of 9
    Fellow Frogger! acf321's Avatar
    Feb 2013
    269
    Default 504 TI Injection problem
    Hi Folks
    Am looking at a 504 Ti, however the owner tells me the F Inj has started to play up and "the car just revs its head off". Does anybody know if this is something that is a common fault on K Injection on a Ti Pug?
    I know its a broad question, but if anyone can shed any light on this, I'd be greatly appreciative.
    Regards
    Adam
    Fellow Frogger! FedGrapes's Avatar
    Aug 2011
    Perth, WA
    835
    Is that revs at idle? Vacuum would be the first place I'd start. All of the vacuum hoses, and brake booster.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,440
    504 TI Injection problem-dsc02973-copy.jpg Accelerator outer cable jumped out of its bracket at the butterfly end?
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    Return spring not working properly
    Blue Mountains, NSW
    433
    Whatever it is causing the revving, it's likely to be minor. A fault in the injection pump can cause too much or too little fuel to be injected. Neither of these is going to cause "revving its head off". Like everyone's saying, too much air is getting into the manifold somehow and the pump is squirting in the appropriate amount of fuel, just as it should.
    Have fun,
    Rob.
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,256
    Sticking throttle cable? Did it in my Ti way back when. Ended in a ditch as I wasn't awake enough to realise what was happening.
    Brendan.
    Aug 2011
    hawthorn melbourne
    482
    Easy to check if its throttle related. Return the throttle spindle by hand . Inner cables can get frayed and not return properly.
    Dandenong Vic
    1,256
    Quote Originally Posted by julian b View Post
    Further to julian b's comment and further elaboration to my comment. The inner can fray, I've found it on the inside of the radius. This then cuts the outer case and the cable gets caught. When replacing it don't be tempted to grease or oil it, just attracts dirt, use graphite powder if you must.
    Brendan.
    12,266
    diaphram ???
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
