406 fuel tank thread issues
Results 1 to 7 of 7
    Jan 2015
    Australia
    12
    Default 406 fuel tank thread issues
    Well I have sort of patched my problem with the fuel pump problem read my previous post,however I have a problem with leaking diesel from the top of the tank I cant tighten the cap located under the back seat as previously stated I replaced the fuel pump located in the fuel tank and since then I have had a leaking tank is there a tool or an idea how to tighten that cap.Thank you.Marty
    1000+ Posts pgti6's Avatar
    May 2001
    1,619
    I had to replace the seal under the screw on cap on my 405 recently as since there's bugger all room to tighten the threaded ring by hand, I resorted to using my cam holding tool.
    Camshaft Holding Tool | ToledoNZ
    Where are you located Marty? If it's Melb, you're welcome to borrow it.
    Attached Thumbnails Attached Thumbnails 406 fuel tank thread issues-tridon-cam-holding-tool.jpg
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Dec 2010
    423
    Sorry to go off topic, but puggti6.. Wher did you get the seal for the top of the tank on a 405? I need one but thought they were not available.
    May 2001
    1,619
    306's have the same seal and being that bit newer than the 405's seem to be plentiful & in good condition secondhand. Citroen Xsara's of the same vintage are different though.
    I got mine from Nick-a-part.
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    Dec 2010
    423
    Thanks. Hopefully I'll find a good one and people will stop telling me that my car smells like fuel.
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    have a look at the charcoal canister, a poor setup if the filter is clogged, feed kinked etc, it might also cause a heavy fuel smell too.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    547
    I needed a new fuel pump for the 307 , and Mitch at Reno Reck told me to never leave a plastic tank without the pump assembly installed and the retaining ring screwed on properly , he had a number of people who removed pump to check it and by the time they received the new part the tank had changed shape and they were not able to get the threaded ring to fit onto the tank again. He had to sell them complete tanks.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
